2011.12.29, 12:35 AM
PN RacingTEAM Driver
2012 R1WURKS.com So-Cal Mini-Z CCS(championship cup series)
2012 R1WURKS.COM So-Cal Mini-Z CCS(championship cup series)
SPONSORED BY: SO-CAL MINI-Z PNRACING
Classes/Rules
BOX STOCK
ALL STOCK PLASTIC CHASSIS, BODY MUST BE KYOSHO ASC WITH ALL PARTS INCLUDED, AND MATCHING KYOSHO WHEELS (WHEELS MUST NOT STICK OUT OF THE FENDERS)
KYOSHO STOCK MOTOR ONLY
4CELL AAA BATTERY
WITH THE EXCEPTION OF:
ANY AFTERMARKET WHEEL BEARINGS ALLOWED
ONLY BRAND RUBBER
(NO SILICONE OR FOAM TIRES OR TRACTION COMPOUND)
F1 REAL:
ALL CHASSIS UPGRADES ALLOWED ie:motor pod knuckles tplate...
FRONT AND REAR WINGS AND BODY MUST REMAIN STOCK ! NO AFTERMARKET BUMPERS OR WINGS
EXCEPTION: DRIVER MAY BE REMOVED FOR TRANSPONDER PLACEMENT
MOTOR: PN 50 70 OR 80 T BUSHING OR KYOSHO STOCK OR X- SPEED ALLOWED
TIRES:ANY BRAND F1 SPECIFIC "RUBBER" TIRES ONLY
WHEELS: ANY BRAND F1 ONLY
(NO SILICONE TIRES OR TRACTION COMPOUND)
PN RACING GT STOCK
PNWC STOCK 2011 RULES
MOTOR
GT Stock Class drivers will receive a sealed hand-out 80T motor (#112080),for each class the driver has registered for. Each motor will contain a control number. The control number will be recorded and assigned to the car that the driver has registered to run in the class. Each motor must remain with the car it was assigned to at the time of registration. The motors are to be run as is. Any tampering with the motor will result in disqualification. If any Race official suspects motor tampering, the driver will be subject to disqualification. Each class drivers can buy one more extra motor.
CHASSIS
GT Stock Class - 90mm to 98mm Wheel Base
Kyosho Mini-Z MR01, MR015, MR02 and MR03 MA010 only. Kyosho colored chassis may be used.
BODY
GT Stock Class Kyosho Mini-Z and TRP Scale body only, Le Mans body allowed, all windshield and window must be installed.
'"EXCEPTION'"
LEXAN WINDOWS MAY BE USED
BEARINGS
any type of bearing by any manufacturer is allowed. For example: Ceramics are allowed.
BATTERIES
All Classes cars must be powered by four AAA batteries. Alkaline, Ni-MH or Ni-Cd batteries may be used. No other type of battery may be used. For example: Lithium Polymer may not be used.
WHEEL RIMS
All brand Plastic and Aluminum rims are allowed.
GT Stock Class,
Maximum front wheel width is 8.5mm. Maximum rear wheel width is 11mm. Maximum wheel diameter is 21mm.
TIRES
Any Brand of Rubber tire ONLY. No foam tires or tires allowed. No tire insert use. No traction compounds allowed on tire or on race surface. Tire warmers are allowed. Tires may be cleaned with a 70% alcohol solution. If a driver uses tire cleaner that has been deemed illegal, the driver will be subject to any penalties that apply. Please address any questions concerning tire cleaners at the drivers meeting.
HOP UP PARTS
Drivers may use any Kyosho or after market parts available. All upgrades must conform to all other rules posted in this document. All upgrades must be designed for the chassis that the upgrade has been installed on. No upgrade will be allowed if the upgrade will interfere with the cars of other drivers. The Racing directory, tech inspectors and race officials reserve the right to disqualify any part deemed improper based on fairness and possible interference.
NO WEIGHT LIMIT
ANY BRAND RUBBER TIRES ALLOWED
OPEN MODIFIED
1/28TH SCALE NATIONAL RULES
Dimensional Specifications:
Body
Length (B): max 180 mm
Width: max 80 mm
Height (C): max 55 mm including wing
Rear wing cord: max 25 mm, can not extend more than 10 mm beyond end of body
Rear wing length : max 80 mm, can not extend above roofline of body
Material : may be either hard plastic, lexan, or carbon fiber
Widows : must be complete except for clearance issures
Apearance :GT OR PANCAR BODYS ALLOWED LEXAN OR PLASTIC
Chassis
Wheelbase (A): max 106 mm, min 86 mm
Track : must fit inside of body specifications
Weight: min 170 g
Drive train : 2WD or AWD, single speed only, belt or shaft system
Wheels
Wheels: Diameter max 21.5 mm
Width : max 12 mm
Material : Any
Tires
ANY BRAND RUBBER OR FOAM TIRES ALLOWED
Diameter : max 27 mm
Width : max 12 mm
Material : rubber only
Traction compound: not allowed
Battery
* 4 cells maximum.
* AAA or smaller size NiMH rated at 1.25 volts or less
Electric Motor
* Industry standard “130” size brushed motors
* Overall maximum diameter: 20 mm measured at whatever point yields the maximum dimension.
* Maximum length: 28.5 mm measured from the mounting face of the motor to the furthest most point of the end bell
* Handout motor class only: Motors can not be tapered with in any way, brushes can not be changed and endbells can not be removed
for any reason. Any evidence of tampering will be means for disqualification.
Electronic Equipment
* Any combination of electronics, whether integrated or independent is allowed.
* No limit for number of external or internal FET modifications to the electronic boards.
RACE FORMAT
Qualifying
* 3 five-minute Qualifying rounds with resorting after every round
SINGLE A Mains
* All A-mains eight-minutes
* Lower mains five-minutes
RACE POINTS PER CLASS
TQ +1 POINT
First 35
Second 30
Third 26
Fourth 23
Fifth 21
Sixth 19
Seventh 18
Eighth 17
ECT....
And so on, scoring one point less for each driver down to last position.
If a driver does not start, he receives no points.
SO-CAL MINI-Z CCS CHAMPIONSHIP FORMAT
So-Cal Mini-Z CCS POINTS - Points will be awarded based upon the final results of each class run at each race using the following scale:
First 35
Second 30
Third 26
Fourth 23
Fifth 21
Sixth 19
Seventh 18
Eighth 17
ECT...
So-Cal Mini-Z CCS SERIES CHAMPION -
Points earned in each class will be accumulated to determine So-Cal Mini-Z CCS Champion
In the event of a tie, the RACER with the most first place finishes will be
declared Champion. If a tie still exists, then 2nd Place finishes will be
used, etc. until the tie is broken.
Season Schedule
Round 1
Feb 4 2012
KENON HOBBY Baldwin Park
Round 2
March 3 2012
Round 3
March 31 2012
NELSONS Palmdale
April 28/29 2012 RCX LONGBEACH
Round 4
May 26 2012
Brooker Tracker in Newbury Park, CA
Round 5 FINAL
June 16 2012
2011.12.29, 01:52 AM
Grant, what are the details for F1 Real?
Thanks I hope to hear more about this series...
2011.12.29, 04:17 AM
Open Mod, huh? Gentlemen, start your tire gluers... Looking forward to it, Grant!
2011.12.29, 07:12 AM
GF Racing
Awesome
Now this will be a series to remember......
GF Racing Team Driver
2012.01.01, 08:18 PM
GF Racing
mmmm...decisions...decisions...what body will I use for box stock???
what motor for F1 Real???
What batteries for GT Stock???
Cant wait for this series....
2012.01.13, 01:07 AM
GF Racing
looking good Im only going to miss one race.....
2012.01.25, 08:53 AM
TITLE SPONSOR ADDED!
THIS IS TURNING OUT TO BE A GREAT CCS SERIES!
THERE WILL BE RAFFLE PRIZES AS WELL AS GREAT PEOPLE AND GREAT FUN!
ALSO AN ADDED NOTE!
R1WURKS.COM IS GIVING A MINI-Z BATTERY SPONSORSHIP CONTRACT TO THE 2012 R1WURKS.COM So-Cal Mini-Z CCS CHAMPION!!!!!
2012.01.25, 10:25 AM
of both Time and Space
Originally Posted by yasuji
Round 3
March 31 2012
NELSONS Palmdale
Is Round 3 at Chad Nelson's home?
2012.01.25, 10:40 AM
yes ! he has a 2500 sqft warehouse in his back yard....to store all his toyz!
2012.01.25, 11:33 AM
Seeing all Chad's toyz would be worth the trip! I guess you'll make him start 3 laps behind the field to make up for the "home" advantage.
2012.01.25, 11:50 AM
talk about "home field advantage"... sounds like you guys are having fun down there wish I had time to join, I haven't left san jose in awhile.
2012.01.28, 07:38 PM
RACE SCHEDULE FOR ROUND 1 @ KENON HOBBY
13200 Brooks Dr, Suite E, Baldwin Park, CA91706, USA.
doors open @ NOON
open practice NOON till 3:30 pm
CLASSES:
SPORTSMAN STOCK
BOX STOCK
PNRACING GT STOCK
F1 REAL
OPEN MOD
QUALIFYING ROUND 1 : 4PM
QUALIFYING ROUND 2 : 5PM
QUALIFYING ROUND 3 : 6PM
OPEN PRACTICE :7PM-7:30 PM
MAINS :7:30 PM
TRACK CLOSE 9PM!
THIS RACE WE WILL ALSO BE HAVING A "GARAGE SALE" MANY 1/10TH SCALE PARTS AND NON MINI-Z RTR KITS WILL BE ON SALE RACE DAY ONLY!
SEE U @ THE TRACK!
2012.02.03, 10:37 AM
feb 4 2012
KENON HOBBY
2012 R1WURKS SO-CAL MINI-Z CCS ROUND 1
2012.02.05, 04:40 PM
2012.02.06, 06:00 AM
For me the best battles had to be in Box Stock, swapping positions with Alex so many times! Btw Alex, I forgot to tell you but your BMW-Williams developed a tiny bit of tweak to the right as the race night progressed. I'm going to need one more tuning day with the car to REALLY make it dance, as well as handle 50t power. I should be able to make your F1 so fast you can't recognize it.
Thanks again to Philip, Grant and Steve for making this happen! I'm definitely not doing 3 classes ever again, I passed out SO fast promptly after getting back to Caltech. :lol:
