Old 2003.06.08, 06:27 PM   #1
walds11
Mini-Z Novice
Help again, trying to mesh pinion gear w/ diff gear!!!
Now that I got the motor mount screws off and mounted the x-speed motor, the pinion and diff gear do not mesh. Any suggestions? I still have the stock diff and will be ordering a ball diff soon. help!!!
walds11 is offline   Reply With Quote
Old 2003.06.08, 06:30 PM   #2
walds11
Mini-Z Novice
By the way, I am using the 6 tooth pinion gear. Should I try the other motor mounts that come with the car?
Old 2003.06.11, 04:06 PM   #3
BobT
BobT's Avatar
You will find a parts tree with black plastic rectangles marked .5, 1 and 1.5. These are used in the motor mount to space the motor for correct gear mesh. With the 6 tooth gear you may have to remove any spacers presently in the motor mount to get correct mesh.
We use these plus thin cardboard pieces in the motor mount to get the best gear mesh.
Hope this helped.
PS: We've found the 8-tooth pinion to be the best setup for our track when running stock motors.
Bob Tierney
BobT is offline   Reply With Quote
Atomic ball diff gear running loud dameetz Parts and Hop-ups 12 2008.05.01 11:18 PM
I broke my Pinion gear :( philophob Beginner Questions 5 2008.03.12 08:58 PM
26T--->28T ball diff gear= longer gear ratio correct? pinoyboy Mini-Z AWD MA-010, MA-015 8 2007.11.05 12:45 PM
Gear Diff hpgod Mini-Z F1 MF-010, MF-015 5 2007.07.11 11:53 PM
Diff Gear Upgrade Snafu car47 Mini-Z Racer MR-02 3 2006.02.23 03:58 PM
