Old 2008.07.15, 09:03 AM   #1
Cherub1m
Slip Angle Chaser
Cherub1m's Avatar
2.4 GHZ F1 Conversion question.
Hi
Will the 2.4 GHZ MR02 PCB fit he F1 chassis without any modifications? I transfered all my car to 2.4 only one remaining is the F1. I just dont feel like pulling the soldering iron out .
Philip Vincent
Old 2008.07.15, 09:45 AM   #2
Nic-Z
Nic-Z's Avatar
Send a message via MSN to Nic-Z Send a message via Skype™ to Nic-Z
I don't remember if I had the 2.4 AWD board or the MR-02 when I did mine but from what I remember it was straight forward easy to do. actually one of the easier ones w/o mods. the servo wires are longer so I think I used an AWD board on it.
1....ok maybe 2 of each.
Nic-Z is offline   Reply With Quote
Old 2008.07.15, 12:16 PM   #3
Tjay
Tjay's Avatar
http://minizracer.com/forums/showthread.php?t=27746
by ruf.
Old 2008.07.15, 05:47 PM   #4
VAzRACER
Team Reflex
VAzRACER's Avatar
Use an MR-02 board. The switch wires need to be 1 inch longer and the positive power wire needs to be 1/4 inch longer. The negitive is ok. You will need to put some small spacers under the shock mount to lift it, plastic wheel bushings work well. The steering wires are ok.
Old 2008.07.15, 06:18 PM   #5
ruf
4play
ruf's Avatar
Finally got around to writing a tutorial... It's been a while, so I'm rusty!
http://www.reflexracing.net/ASFF1_conversion.asp
Joe Chen
Houston, TX
Mini-Z World Champions!
Reflex Racing Blog
Reflex Racing YouTube
Old 2008.07.25, 01:09 PM   #6
Cherub1m
Slip Angle Chaser
Cherub1m's Avatar
Great, thanks everyone I just got another MR 02 LM 2.4 that has the name of my F1 .
After this...My work is done. All will be ASF
Philip Vincent
Old 2008.07.26, 12:55 AM   #7
Cherub1m
Slip Angle Chaser
Cherub1m's Avatar
<-----that smile is for...it is done the transformation is complete. Just finished the F1, now all my miniz's are ASF
Philip Vincent
2.4 Ghz strange behavior remy 2.4GHz ASF System (Auto Selected Frequency) 17 2008.09.12 11:56 AM
2.4 Ghz AWD Chassis/Bearings frido 2.4GHz ASF System (Auto Selected Frequency) 4 2008.08.07 11:15 AM
WTS Hopped up RTR 2.4 GHZ MM Red Fxx Jebroni Mini-Z Marketplace 7 2008.04.23 02:19 PM
2.4 conversion set pfcparts Mini-Z Marketplace 6 2008.03.28 12:27 PM
CP Cup Car & Truck conversion question ExtraPickles Miscellaneous Discussion 0 2004.11.11 07:52 AM
