Old 2009.05.09, 01:47 AM   #16
Skv012a
Skv012a's Avatar
Hfay, used since season 7 started. Haven't had similar issue on stock diff, so I don't think its the motor. I did add a thin nylon atomic spacer/shim between the adjustment wheel and the bearing, but after tightening the diff, there's some clerance in that area so I ruled that possibility out. Bearings and their holders sit very tightly, so it shouldn't be those either.
New site.
Old 2009.05.09, 01:52 AM   #17
Check to see that there are no bent teeth on the spur/pinion...
Old 2009.05.10, 04:45 AM   #18
Skv012a
Skv012a's Avatar
Teeth are all fine. Whats funny is that my gear diff sounds and works perfectly fine with this mount as opposed to this 3R ball diff. I might go through my extra spur gears and see if there's a higher pitch/tooth one that would mesh well with 8-10 tooth pinion and see if it gives me better results.
New site.
Old 2009.05.25, 04:04 PM   #19
Skv012a
Skv012a's Avatar
Soy helped me figure this out last night- the pinion was rubbing on the edge of the rim and thus created vibrations and limited me meshing the gears closer. All good now and niftly little detail to learn.
New site.
Tags
ball, diff, differential, mr02, mr15
Ball diff changes... HaCo Mini-Z Racer MR-02 4 2007.07.15 03:26 PM
PN Ball Diff vs. Kyosho Ball diff briankstan Mini-Z Racer MR-02 15 2006.08.15 06:54 PM
Ball diff problem bobman Parts and Hop-ups 15 2002.03.01 09:32 PM
Ball Diff Ball Diff Ball Diff Ball Diff II Chezedog Mini-Z F1 MF-010, MF-015 1 2002.02.27 02:40 PM
Ball Diff Ball Diff Ball Diff Chezedog Off-Topic 37 2002.02.11 12:12 PM
