Old 2003.02.14, 01:03 PM   #1
NSX-Fan
NSX-Fan's Avatar
Talking Does 9.5mm Tires fit AMG Front Wheels?
Hello,
Probably a simple question for most of you... does 9.5mm Kyosho brand tires fit on Mercedes AMG front wheels(I believe the front wheels are standard width)?.
I've bought some soft wide tires for my rear, but now I need some soft front tires to go with my setup. I believe default front tire size is 8.5mm. Thanks for your help!
NSX-Fan
NSX-Fan is offline   Reply With Quote
Old 2003.02.14, 02:25 PM   #2
Draconious
Draconious's Avatar
In my opinion the standard 8.5mm wide rims should be using the 9.5mm tires, cuz all the stock tires I have seen dont realy cover the rim all the way.. so a 9.5 rubber on a 8.5 rim might just hang off a little.. wich would simulate some brands of tires.. (as if I know wich brands) but not all are flush with the rim...
Old 2003.02.14, 03:07 PM   #3
Fish
Fish's Avatar
Send a message via MSN to Fish
9.5mm tires are almost perfect for 8.5mm wheels.
Putting 11mm tires on the 9.5mm wheels also works well. The overhang is minimal, and it looks real good to boot.
miniRC ca
Fish is offline   Reply With Quote
Old 2003.02.14, 03:19 PM   #4
NSX-Fan
NSX-Fan's Avatar
Thumbs up
Thank you Fish and Draconious for your help. Now I feel better about ordering the parts!
Old 2003.02.14, 10:35 PM   #5
old thread... i found...
http://minizracer.com/forums/showthr...ht=track+width
i totally agree with drac & fish (hmm...all of a sudden, i feel hungry...)
you can put in the semi wide tires on them standard tires... it fits a whole lot better than the standard tires...
Wall Hits Peeling Off Front Tires bemoore Mini-Z Racer MR-02 15 2006.02.02 03:01 PM
10 degree front grooved tires dskapyak Mini-Z F1 MF-010, MF-015 9 2004.11.02 10:00 PM
F-40 Pics and what alloy wheels will fit Xanatos Parts and Hop-ups 1 2002.12.15 10:51 AM
These tires fit??? Mirage Parts and Hop-ups 8 2002.05.09 09:40 PM
wheels? Tires? What? ViperKid Parts and Hop-ups 3 2002.05.01 10:06 PM
