Old 2013.02.23, 11:06 PM   #1
rdlkgliders
Transponder Help
I have a new mr 02ex and a giro z transponder from pn. The car is on its 3rd transponder, suddenly while racing it will just quit registering. When I test it on another car the transponder does not work. This has happened 3 times now.
Any Help?
rdlkgliders is offline   Reply With Quote
Old 2013.02.24, 12:14 AM   #2
I-Lap
Make sure the IR LED is not hitting the body. If it is, it can break the LED internally or crack the solder joints/PCB pads.
Inspect the solder joints closely. They may just need to be touched up if they are cracked.
I-Lap Timing Systems
Precision Timing for Small Scale Motorsports
www.rclapcounter.com
I-Lap is offline   Reply With Quote
Old 2013.02.24, 01:38 PM   #3
rdlkgliders
thanks for the response. I always test without body first
Old 2013.02.24, 06:53 PM   #4
ChiMiniRc
It's the putting on the body that might be the issue. If the LED on the top is crushed down it can break. That may explain why moving it into another car has prevented it from working.
Old 2013.02.24, 09:19 PM   #5
I-Lap
I didn't mean the body was blocking the signal.
If the body or window physically touches the IR LED, it can damage it. Then it won't work without the body or in another car as you have stated.
Old 2013.02.25, 10:07 PM   #6
rdlkgliders
After taking a closer look at where the transponder mounts I think there is a good chance that the body did damage the laser.
Can I get a new laser if so what is the right one and does anyone repair them?
Thanks
Don
Old 2013.02.25, 11:15 PM   #7
I-Lap
TRP has a listing for them, but no stock and no actual component part number.
I was doing some parts orders today and I added a few pieces of what looked closest. I'll let you know in a few days when they arrive how close they are and we'll go from there.
Are you in the USA?
Old 2013.03.01, 10:28 PM   #8
rdlkgliders
Thanks Keep Me Posted
Old 2013.03.09, 06:10 PM   #9
I-Lap
Sorry about the delay.
This is the replacement LED:
http://www.mouser.com/ProductDetail/Everlight/IR91-21C-TR7
It is physically identical and the 940nm output is typical for the type of receiver they are using.
I replaced one and bench tested it, seems to work fine.
It's an easy fix, even with modest soldering skills.
Just be sure to orient it properly, it won't work backwards.
-Craig
Old 2013.03.31, 01:29 PM   #10
rdlkgliders
Thanks Craig,
I will order a few and fix the broken ones at our track.
Old 2013.11.27, 05:24 PM   #11
Have you had any success in repairing your transponders?
Old 2013.11.28, 05:11 PM   #12
Mike Keely
I have had good luck soldering the original LED back onto the transponder.
DG-Designs / Brooklyn Hobbies
*NEW 2013* Updated I-Lap Transponder for Mini-Z coming soon! Felix2010 I-Lap 14 2015.11.07 10:37 PM
Giro-Z Transponder Sign-up arch2b Washington DC Area GTG, MD/VA/DC 6 2014.02.01 11:51 AM
*NEW 2013* Updated I-Lap Transponder for Mini-Z coming soon! Felix2010 New Products 4 2013.01.16 01:19 PM
New Hiz Transponder compatible with Giroz Huriz Lap Timing Systems and Software 19 2012.11.12 02:14 PM
Transponder on MR03's ICS port? ianc Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 8 2009.12.24 05:06 PM
