http://www.teamlosi.com/Products/Def...rodID=LOSB0230
Fully independent suspension with friction dampers
Differential-equipped transmission
Powerful, pre-installed micro motor
Included Ni-MH battery pack with portable alkaline automatic peak charger
Team Losi 27MHz radio system
Electronic Speed Control with Reverse
High-traction rubber tires on pre-mounted on durable nylon wheels
Includes 8 AA heavy-duty batteries for transmitter
Includes 8 AA alkaline batteries for charger
Overview
Team Losi is out to take RC to every level with the Micro-T. The Micro-T is the smallest RTR that Team Losi has ever offered, coming in at just under 5 inches long. But just because it’s small doesn’t mean it skimps on performance. Packed with a Ni-MH battery pack, independent suspension, differential equipped transmission, automatic peak charger and 27MHz Team Losi radio system, the Micro-T has the speed and handling to tackle everything from the tabletop to the tile. Take it with you anywhere you go and satisfy your need for speed with the Micro-T.
Product Specifications
Type: 2WD Stadium Truck RTR
Scale: 1/36
Length: 4.5 in (114mm)
Width: 3.5 in (89mm)
Wheelbase: 3 in (76mm)
Weight: 3.4 oz (96g)
Chassis: Composite tub
Suspension: Independent
Drive Train: 3-gear transmission w/gear diff and slipper
Tire Type: rubber multi-pin rear/ribbed front
Motor or Engine: Micro Electric
Speed Control: Electronic Forward/Reverse
Radio: 27MHZ AM Pistol
Servos: Sub-micro
Batteries: 4.8v, 150MAH NiMH (included)
Charger: Peak (included)
Wheel Size: 0.75 in (19mm) diameter
Kit/RTR: RTR
Shock Type: Coil-Over Friction Dampers
Body: Factory-decorated Stadium Truck
Ball Bearings: BB-Equipped Transmission
not sure if this is the right section so mods move the thread if necessary
I wonder if I can get the body and wheels to fit my chassis if I convert it to 2/3AAA I can shorten the wheelbase to the same as that thing muhahaha... give it some compitition .
mmmm this thing sounds awsome... sort of screams make me stupid fast XD. What size motor do yall think it'll use? Any chance of upgrades and blingage? (I think i'll be needing some alloy.... )
Finally, something new in sub 1/28 scale. I am getting excited about this one for sure. I must admit that I did not expect this. This could be a very popular product for indoor racing due to its size if the performance is decent.
put a better motor in it, use my better transmitter adn i htink these could be an absolute blast on the track! even the rcp jumps would work very well. see the dc gtg subforum for overland track pictures/video
