Originally Posted by pchan0
I'm in, what is the handout tire for AWD mod class? Is it their front 40 x groove pattern? Rear is open right?
here are the rules and times.....
Race Schedule
March 29, 2008 - Saturday
9:00 AM: Registration, handout motors/tires. At this time track will be closed
10:00 AM - 12:00PM: Controlled Practice
12:00 PM to closing: 1st and 2nd rounds of qualifying; with limited practices in between
March 30, 2008 - Sunday
10:00 AM: 3rd qualifying rounds
1:00 PM: Mains
We will have trophy presentations after the Mains.
Rules
Formula 1 Stock
Chassis: Mini-Z F1
PCB: Kyosho Mini-Z circuit board / RV Project Fine-Tune Unit board with AM 27mhz Frequency (3004 or 3010 FET) (No modifications allowed; No AD-Band; No 2.4Ghz; No additional FETs or turbo)
Motor: AR-076-B, Standard BB (Hand Out)
Min. Weight: 210g READY TO RUN
Max Wheel Base: 130mm
Max Car Length: 205mm
Max Car Width: 85mm
Max Car Height: 50mm
Car Body: Kyosho Mini-Z F1 Auto Scale Body
Rims: Any brand allowed as long as it is the same size as the F1 rims that come with the kit. Front width: 13.5mm; Rear width 15.5mm
Tires: Rubber tires only. Any Brand Allowed. Diameter must be the same as Kyosho made F1 tires. Traction compound not allowed. FOAM tires not allowed.
Batteries: AAA size batteries 4 cell, alkaline, NiMH or NiCd only. No Lithium or other type of battery allowed.
Frequency: AM27 MHz
Transmitter: Any Brand AM27 MHz transmitter is allowed.
Option Parts: Any aftermarket hop-up parts are allowed.
Three qualifiers and One Main, each main is 8 minutes.
2WD Stock
Chassis: MR01, MR-015, MR-02
Min. Weight: 180g
Max Wheel Base: 106mm
Max Car Length: 178mm
Max Car Width: 80mm
Max Car Height: 45mm
Car Body: Kyosho Mini-Z Auto Scale Bodies only
Rims: Any brand allowed, rims must fit within the width of the car body.
Tires: HANDOUT ATOMIC Rubber/Silicon tires. Front (AR143); Rear (AR146). Traction compound not allowed.
Frequency: AM27 MHz
AWD Modified
Chassis: MA010
PCB: Kyosho Mini-Z circuit board. AD Band is allowed. 2.4Ghz is allowed. FET modification allowed. No aftermarket electronic or ESC such as NOVAK or TEKIN.
Motor: STOCK-R (MO-006 Hand Out)
Min. Weight: 190g
Max Wheel Base: 98mm
Max Car: 80mm
Tires: HANDOUT ATOMIC Rubber/Silicon tires. Front (AR143); Traction compound not allowed.
Frequency: AM27 MHz. AD Band Channel
Transmitter: Any Brand transmitter is allowed.
Three qualifiers and One Main, each race is 8 minutes.
2WD Modified
Chassis: MR01, MR-015, MR02.
PCB: Kyosho Mini-Z circuit board. AD Band and 2.4Ghz is allowed. FET modification allowed. No aftermarket electronic or ESC such as NOVAK or TEKIN.
Motor: Chili Modified Motor (MO-007 Hand Out)
Min. Weight: 180g
Max Car Width: 80mm
Tires: HANDOUT ATOMIC Rubber/Silicon tires. Front (AR143)). Traction compound not allowed.
Batteries: AAA size batteries 4 cell, alkaline, NiMH or NiCd only. No Lithium or other type of battery is allowed.
Frequency: AM27 MHz or AD Band
