Old 2015.01.17, 11:49 PM   #1
deadted
Shock upgrade-leaking stock shocks
Can't seem to keep my stocks shocks from leaking or holing oil long term. Any suggestions? Are there any aftermarket shocks that are an improvement? What about the Kyosho aluminum aftermarket any better
deadted is offline   Reply With Quote
Old 2017.02.13, 06:05 PM   #2
Mughal86
It is tough to stop the shocks from leaking. They always seem to leak a little. I purchased the aluminum Kyosho shocks and though they are smoother, they also leak from the top caps. I have not tried this yet but I believe plumbers tape should fix the problem if they are leaking from the top. Just wrap a thin layer on the threads and tighten the caps(careful not to over tighten). I will try this method for myself later this week and let you know how it goes. That is a good solution from what I have been reading.
Mughal86 is offline   Reply With Quote
broken servo wires/cheap shock upgrade aaron Mini-Z Monster MM-01 2 2007.03.29 04:01 PM
rear shock upgrade for mr-015 really needed? doongas Parts and Hop-ups 2 2006.05.04 01:38 PM
Best all around Stock Motor to use without Fet upgrade Warchild Motor Tech 37 2005.11.07 08:33 AM
bearing and shock upgrade pHREDD Mini-Z Overland MV-01 8 2004.01.30 10:23 PM
