Old 2018.06.22, 11:22 PM   #1
Blf
Best lap timing system with bridge
Ive been using the IC tags for a while but wanted to know what the best current systems out there that will work with flipside and will not suffer from interference/occasional missed laps
Easy lap? Who else?
Old 2018.06.23, 05:18 AM   #2
I-Lap. Very reasonably priced as well. Will run Flip side, Giro-Z, AMB and several others. Transponders quite inexpensive.
Old 2018.07.05, 04:26 PM   #3
ChiMiniRc
+1 for I-Lap. I used it for years running the Chicago Mini R/C Club without a hitch. Inexpensive transponders.
Old 2018.07.06, 06:14 AM   #4
Keep in mind, whatever you buy, something else will come along... PN changes timing systems almost as frequently as we change tracks
Domestically, Easy Lap and I-Lap are the predominate choices. I've not used Easy Lap before and cannot comment on it however I-Lap is reliable. They all have their quirks though.
Old 2018.07.06, 08:26 AM   #5
From a customer service standpoint I-Lap is second to none.
Old 2018.07.06, 08:59 AM   #6
Good point. Craig of ILap is fantastic to work with. If you ever have a problem, you donít need to worry about dealing with overseas email, phone calls.
Old 2018.07.06, 11:01 AM   #7
TPDazzle
We use Easy lap. It has been very reliable and easy enough to get from Kenon. I bought it because we have a very small club, so cost was a huge deal for us. The transponders are much smaller than iLap and half the price. We use it with Zround, so I can't speak how it works with other software. I was very concerned about customer service if we had a problem, but everything worked flawlessly other than you must select Robitronic USB instead of Easy lap to get it to work in Zround. That said, I bought a ILAP transponder for a race in Portland and I needed to get some extra wiring harnesses after I messed up my first order. They were fantastic to deal with and FAST.
One hint: if you go with Easy Lap, figure out how many transponders you need with your initial order. The transponders are super cheep if ordered with the initial system. If you order 5 they are only $11 each.
Best Lap Timing System & Software 2016? jevs Lap Timing Systems and Software 28 2018.11.01 07:54 AM
Kyosho's Lap Timing System? soulstice Lap Timing Systems and Software 36 2011.02.16 08:28 PM
WTB: Lap timing system oramac Mini-Z Marketplace 1 2008.08.14 03:51 PM
The Ultimate lap Timing System Soon to Be Released RCPMini-z Lap Timing Systems and Software 74 2005.03.11 10:35 AM
