2008.06.18, 11:01 PM
3PK 2.4 ASF work good!
Today I use modify AD module method, modify my to my Futaba to 2.4 ASF Mini-Z, it s work great, everything same as my EX10.
http://www.reflexracing.net/module.asp
2008.06.18, 11:17 PM
iTomCash
That's awesome.
I was curious if the module helped iron out the reverse delay on the 2.4?
2008.06.18, 11:51 PM
putting ew back in newb
Originally Posted by Programmers
That's awesome.
Wondering the same thing. Anyone heard of any adaptation of a Spektrum DX3R? Subscribed.
My Gallery "those now old and wise, once were young and otherwise."
2008.06.19, 12:52 AM
Glad you liked our tutorial Philip!
2008.06.19, 10:18 AM
Originally Posted by crazyracer
Thanks for sharing the info crazyracer . This is a very good news to me as I was about to order the combo set of EX10, I guess I just need to order the 2.4 module then and convert it to my 3PKS. Now,where can I buy Futaba module casing?
p.s if you can pls post pic of your modded module? Just need to see how do you mount the antenna.
2008.06.19, 10:47 PM
you could easily buy an FM module on the Bay for a couple bucks.
I would like to know if the board can be programmed around it's delay that i've heard so much about...with my poor driving skills I need all the help i can get.
2008.06.20, 11:09 AM
Team ShoBoi
How did you get it to fit the 3PK's module compartment?
2008.06.20, 11:26 AM
Need a mini z Painted????
When is the Airtronics module coming out??
Dave Graboski
DG Designs
2008.06.20, 11:59 AM
Peter, I just use two JST make wire, the plug for 3PK 1st and 2nd pin, connect to KO 1st and 3 rd pin, and othe plug for 4th and 5th pin, connect to KO 4th and 5th pin, and use waco tape the KO module on the 3PK.
2008.06.20, 01:56 PM
I dont get it. Did put the KO board inside the Futaba module casing as per reflex racing tutorial? Can u pls post some pics?
2008.06.20, 07:37 PM
sounds like he used a couple wire leads and plugs and just taped it all up...very ghetto.
I guess I won't be getting my question answered.
2008.06.21, 02:16 PM
PN RacingTEAM Driver
i got to see this mod last night......basicly it looks verry cool and makes perfect sence for crazyracer as he has both radios...ko and 3pk.....
in a nut shell....he has 4 wires coming out of the ko module.....for the 3pk you plug in the wires and attach the module w/ velcro to the side of the 3pk...
if he wants to, he can simply unplug form the 3pk and insert the module into his helios in seconds..... ...in my book that is smart thinking !!!!!!!!!!!!!!
needless to say, he didnt have to waste a 3pk casing ,or waste a 2.4 module
great mod crazyracer!
2008.06.21, 03:46 PM
Please get some good photos up of what was done and how it was done. As a lefty this is a necessary mod for me.
2008.06.25, 05:26 PM
Pictures
2008.06.25, 07:31 PM
Phil
Thank you very much for the post and EXCELLENT pictures. From here I can get my soldering Guru to take over. Thanks again
