2005.01.07, 11:36 AM
Kyosho Autoscale body on Iwaver 01?
hello,
I saw some very good looking autoscale body's for mini-Z's, my question is: do they fit on the 01 Iwavers? or do you need to make some mod's? if so, what do you need to do?
Theo
2005.01.07, 11:47 AM
fast and out of control
Originally Posted by Theo
hello,
Theo
01 bodies should fit on the 00 and 01 iwavers as thhey have the same chassis design. You may need to change wheels (depending on the offsets) and front clip but they all come with the autoscales...
2005.01.14, 10:56 AM
I bought a McLaren F1 body, It's for MR-02 MM, didn't know that it's a mr-02 body
The motor doesn't fit in the body, should i change the motor position?
And the antenna needs to be bended forward, is this bad for the antenna?
I hope it can be mounted properly, it was expensive
thanks in advance,
Theo
2005.01.14, 12:45 PM
thanks in advance,
Theo
is your 02 an MM or RM (silly question but that would be the simplest)...also what hop up parts and settigs is it on? (ie where is the H-Plate and the like).
2005.01.14, 01:40 PM
It seems Theo have a IW01.
This means that it is hard to fit that body. In my opinion a proper fit is impossible
Sinister
2005.01.14, 02:24 PM
yeah wolf, i've got an 01.
I will try to get my money back.
thanks for the answers,
Theo
2005.01.14, 02:34 PM
why not try to swap for an mr-01 body with someone?
2005.01.14, 02:59 PM
I Apex Like poop
Good call from minizracings #1 custom overland roofrack whore! (in case there is confusion, that is a compliment)
ATTN SHOP OWNERS!
I will trade professional graphic design and photography services in part or whole for Mini-z's and parts. Pm me for details
2005.01.14, 03:17 PM
thanks, i think
i have a lambo svr, red that's nearly brand new or even an unpainted lambo svr body....
2005.01.14, 05:10 PM
I Apex Like poop
thanks, i think
to act my age and speak it in english:
i very much admire your roofrack craftsmanship and addiction, amazing work... the best i have seen here thus far.
ATTN SHOP OWNERS!
2005.01.14, 05:13 PM
2005.01.15, 02:23 AM
That's a good idea, but I can also buy a 02 chassis. That way i've got 2 cars (i've got another radio) And i can keep my body
I love the McLaren F1
thanks,
Theo
2005.01.15, 04:11 AM
if you still want to stick with the mclaren, buy a mr02 mm motormount (i think this will be the cheaper alternative) to fit on your iwaver01... then find the proper rims to go with the body...
2005.01.15, 11:25 AM
you mean the: IWaver-02 Motor case (RM/MM) ?
it's only €4.95.
If that's the solution, I'll order one!
thanks,
Theo
