2011.09.14, 04:19 PM
#31
Top shock spring, lower tower (thought I wouldnt spot it through the wheel), green antenna
I would assume that you have the new diff parts, I just got them in, and have to start rebuilding all of my diffs.
2011.09.14, 04:44 PM
#32
Mini-Z Norway
Correct EMU Good eye! Also. Check out the rear.
If you take a peak into my blog you see the rest of the pictures.
The antenna is just "use what i have" so its not for showing of
2011.09.14, 05:01 PM
#33
rear diffuser
2011.09.14, 08:50 PM
#34
does it look like it has enough room to run the stock kyosho 03 kingpin upside down using the reverse kingpin springs?
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2011.09.17, 11:15 AM
#35
Cant wait to have the diffuser...
2011.09.23, 07:09 PM
#36
New Stuff Coming
RX1187 Reflex Racing Mini-Z Pinion Caddy
RX1186 Reflex Racing Aluminum Diffuser for Reflex Racing and Atomic Motor Mounts
Also, just got the molds in for the new wings. These should be here inside of 2 weeks.
2011.09.23, 07:40 PM
#37
pinion caddy is awsome! i hate digging through parts bins looking to them.
2011.09.23, 08:38 PM
#38
caddy coming in all RR colors as well
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2011.09.23, 08:51 PM
#39
y is aluminum chosen for the diffuser? weight and heat dispersion?
2011.09.23, 09:30 PM
#40
Yes, it was made in aluminum because it would dissipate heat better, last longer and also because it places weight all the way back and low. The MR-03's are so light with all the new parts made and the heavy MR-02 friendly PN rules make it really hard to bring the cars up to race-weight. This diffuser, along with the top deck are part of our slightly heavier than stock accessories that have been designed with weight placement in mind.
The caddy will be available in black, gray and light blue. We did not do silver because the lettering does not look very well.
The diffuser will be available in black only. It just looks better
2011.09.23, 09:32 PM
#41
what's the weight for the the diffuser?
2011.09.24, 10:38 AM
#42
Cant wait to get hold of it soon! and more of RR new parts.
2011.09.25, 06:50 PM
#43
i see the new stuff on your site. are they available or just pre orders?
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2011.09.25, 06:52 PM
#44
never mind just went back to the site and it has changed to the pre orders at the top of the page. i know it wasnt like that 30 min ago
PN Racing
R1Wurks
LET's Go Racing
DG Designs
2011.09.25, 10:17 PM
#45
It's been like that for a couple of days. Our landing page design is not totally done, but it does have the incoming part list that should stay there from now on.
