Old 2016.05.15, 07:03 PM   #1
jcstuezday
†hazel 5'7" mayan owl†
jcstuezday's Avatar
Mini-Z Brushles Motor Idea
Why not make a plug in on the back of each Brushles Motor and use a servo 3 wire with mini plug to snap in the back of the brushles motor....yu can do this also to a 130 and 180 and 300 size motor....
Like a servo wire and conector just a smaler conector....
Justin
420T2520
jcstuezday is offline   Reply With Quote
Old 2016.05.15, 07:28 PM   #2
What would be the reason to or purpose for this modification?
Old 2016.05.15, 07:42 PM   #3
DMALMAD
DMALMAD's Avatar
Atomic already uses a similar idea where they use a battery plug. It really is useless though because you are adding another possible point of failure for literally 30 seconds of soldering.
ATOMIC RC TEAM DRIVER
rcatomic.com
demracing.net
Old 2016.05.17, 01:44 AM   #4
jcstuezday
jcstuezday's Avatar
for 1/18 scale the purpose iz like a precut lexan body people forget to what they need and that need iz true to the foam tire to have a servo wire conect to a 180 size brushless motor in the back.... the original brushles wire are large and heavy in 18 scale so it would be pas down from 18 scale to 27....
420T2520
