I ordered a few of them thinking I could use them with my existing diffs but I don't see bow it will work/sit flush with the pressure plates from any manufacturer..... Assuming these are not even a fit with modification or is there an LSD housing I need?
Ivr been modifying my kyosho diffs to accept the reg 64p spurs and would like your try these out somehow as it seems like I neat concept.
I use them and like them. Should be a direct replacement for the regular PN 64p spurs, no additional modifications needed. Did you get the ones for Mini-Z? What part number did you order?
Can you only use pn plates? I don't have it in front of me but I think the kyosho ball diff plates seem to leave a lot of room on t the outer portion - smaller diameter
I have them on diffs with Kyosho plates and QteQ diff parts with no problem. But you do have to sand the inner QteQ and Kyosho diff part flush with the plates to avoid binding. But this would be required on regular PN 64p spurs too.
Just got one on a pn copy( x power) diff and yes it works but you can see a tiny bit of the exposed ceramic ball slots at the outer edge of the plate. Same with kyosho plates .....I any take a pic at moment but it seems like tire / rcp debris will get in there easy and foul up the action of the balls moving in the slots
Yes the Kyosho diff plates, you will see more of the ceramic ball on outer edge of plates. The PN plates cover them more. Never really noticed any issues with the Kyosho plates and ceramic balls showing more.
I mostly use the full PN diffs now....just like them better.
Reflex used to be the US authorized dealer, but I've been out of the mix for 3 years, so don't know if that is still the case. I may have an extra new set laying around.
Why do the spurs seem so loose/wobbly with all that play even when the diff is set at normal slippage - the reflex and pn LSD
Spurs seem to have it there worst - any fix for that or is it normal?
