2013.01.05, 07:04 PM
LGR's New carpet!
Some of y'all may have heard, LET's Go Racing is changing over to CRC carpet! We received the carpet this week, and will begin the construction of a sub-floor on Monday. In the mean time, we decided to lay it out to settle, and HAD to throw some walls on it to see how it drives. I am totally impressed. Here are a couple of pictures of my thrown together, make shift, temporary layout, as well as a video of my mod Mini Cooper. The Mini Cooper is running the same set up as I was running on RCP, except I went from an Atomic USA motor, to a PN43T, and changed out my 18mm rear wheels for 20mm.
http://www.youtube.com/watch?v=_rt2j...x0HbaQ&index=1
More pictures to come as progress happens!
Landon
LET's Go Racing!
2013.01.05, 07:17 PM
what will be your subfloor structure and what will you use to adhear the carpet to the subfloor and what is used at carpet seems? just curious as i have never installed roll carpet myself, just carpet tiles.
2013.01.05, 08:15 PM
The sub-floor will be a double layer of 3/4" plywood with the joints staggered so that nothing lines up except the edges. I am prepared to carpet tape the whole thing down, but CRC recommends just taping the seems from the bottom with double sided tape, and taping the edges down with duct tape. I will cover the edge with a 4x4 to keep it looking clean. They also recommend that if you have to tape the seams on top, that you use gaffer's tape instead of duct tape, as it is textured and has grip. If the double sided tape is done right, I shouldn't have anything on top at the seams.
Landon
LET's Go Racing!
2013.01.06, 12:06 AM
of both Time and Space
Very nice Landon. What tires were on that Mini? I'm definitely going to have to try this out!
2013.01.06, 12:13 AM
Slip Angle Chaser
Welcome to the carpet Landon. Carpet is just the best surface for the Miniz's.
Philip Vincent
2013.01.06, 02:43 AM
Very nice. What's happening to the RCP track setup? If you're not going back to that, is it possible to put the carpet on elevation too? That would really make the track stand out.
2013.01.06, 07:29 AM
Instead of elevations, I was thinking if the subfloor is built stiff enough, cables and pulleys could be used the change the pitch of the entire track!
2013.01.06, 08:36 AM
That sounds kind of "kinky"
2013.01.06, 09:25 AM
Slip Angle Chaser
Whatever design you make Landon, I am sure it will be top notch. Also thanks for the video. No way can a Mini Cooper run that fast on RCP without flipping.
Philip Vincent
2013.01.06, 11:23 AM
Ask Maj in NJ what tape they use for the lexan windows. It is very sticky and made for carpet installations.
DG-Designs / Brooklyn Hobbies
2013.01.06, 12:37 PM
Im running LM 20 fronts on the rear with 40 slick fronts on Mantis Group C front wheels. It's so awesome being able to run a real mod!
I guess we will know soon enough!
I will keep the RCP track, and all of the elevations. We can go back to RCP and elevations for special events whenever we want with very minimal effort. I am hoping we can run some bigger scales, and possibly some off-road vehicles on the track along with the Zs, so I'm not sure what will happen as far as elevated carpet goes. I am already working on a plan for how to do it though, so it is not out of the realm of possibility
I don't think the sub-floor will be that rigid. I am almost 100% sure my ceiling wont support the weight of it though! I think it would be cool to build the flooring some what flexible, then have cables in strategic locations to lift and lower certain sections giving a more fluid, subtle elevation change. It would be more realistic than what I've done in the past....just not as space efficient.
Thanks Philip. With an open canvas I think I will have some fun drawing up plans and laying down new tracks! I've already got layouts better than the ones posted! Stay tuned for more vids and pics
Thanks Mike. WE used to have a carpet track with foam walls. I found a great tape that worked really well. I found some it again, and will start with that. If I have any trouble with it, Ill see what Maj used.
Landon
LET's Go Racing!
2013.01.06, 09:24 PM
as a newb to miniz racing i was skeptical, after 5 minutes of bashing, i love it
2013.01.07, 08:19 PM
Realy looks good, can't wait.
Andy
LET'sGo Racing
2013.01.08, 11:59 AM
PN RACING TEAM DRIVER
Hi landon just curious to see what kind of tires you guys use on the crc carpet. I dont think its silicone tires work on it. let me know your thoughts.
Johnny Themelis
PN RACING
MAJ'S HOBBY SHOP
THEMELIS FACTOR RACING CELLS (TFR)
2013.01.08, 12:38 PM
Sammich, I'm glad you had a good time with it. I think with a proper layout, the fun factor will go WAY up!
Thanks dad! I hope to have some good pics today of the sub-floor. we are on to the full sheets, so it should start moving quicker soon. Right now we are putting in the loop for a possible future AMB timing system.
Johnny, Set up development hasn't really started yet, but initially the Kyosho tires I was running on the RCP worked the best. After the sub-floor gets done (tomorrow is my guess), then testing will move into a more aggressive phase. I'll keep every one here posted. "What tires" seems to be the big question so far
Landon
LET's Go Racing!
