Hello people, this is my first post at this forum and unfortunately I am not here for good reasons
My mini-z mr-02 have been stopped for about 2 years. Two weeks ago I've decided to put it back in action but a problem with the steering is making me upset.
So, the problem is that whenever I turn on my mini-z and my controller, the steering starts glitching and it doesn't let me center it.
To help you understanding what I am talking about here is a video I made
Is antenna on transmitter fully extended? Is antenna on chassis securely fastened? Transmitter batteries new or in good condition? Tried to place transmitter and receiver farther apart? Screws that attach board to chassis secure? Transmitter crystal in transmitter and receiver crystal in car? Take everything back to basics. One at a time so when you locate the issue you will know what it is. Good luck and welcome to our insanity.
best result I found when ran am was with kyosho KT3 handset(tried kt5,acom,ae,futaba glitching galore ) an any electricial equipment close by causes interference greatly.
have a read here worked great for me but had to go 2.4 in end http://mini-zracer.com/forums/showthread.php?t=31699
Mates, I've already re-soldered every single wire into the board and in the potentiometer, I've changed the antenna, I've tried to control it from different distances and all I got was that annoying problem!
I don't think I've much more things to try and I'm getting really upset because there is a new track in my town and I can't teach my slow friends how to drive
Do you guys have any suggestion? How much does a new electric board costs? Is it better to spend money on a new one or to invest in a MR03?
I am not in the mod to spend a lot of money, so fixing this problem would be really great!
hmm... the transmitter looks a bit different... does the same thing happen if you try going back to a kt-5 or kt-2? have you tried a different set of crystals?
in the second video it sounds like something is binding... did you try cleaning out the servo gears?
apart from that maybe you can try changing the servo motor?
wish i could be of more help...
you might find a cheap mr02 these days... at least you'll have spares when you buy it vs. purchasing a board only... good luck... and let us all know how it turns out...
Set the radio to center, there is a little silver dial on top of the board you can use to center the servo to the radio.
I can't see the vids here at work but it sounds like a crystal issue to me.
If it's not that, then I'd make sure the antenna is away from any kind of carbon fiber.
If there's still an issue, I'd swap the potentiometer... might be a hairline crack in it.
The servo is going to spin until it makes the pot find center when it's all out of the car. I can usually slowly turn the potentiometer with my fingers until the motor stops.
Where are you from?... I'm curious as to what track is opening up.
Odd note here... crystals seem to have a shelf life. I can't explain that but in my AM history, some of my older crystals would just act up occasionally. Also, the old radios can get funky if they get bashed around a bit, I've got a whole box of sketchy AM radios in my shed collecting dust!
Yeah, check or try another pot. The way it seems to go to extremes would indicate an open circuit between the outer terminals.
If the motor is connected, I didn't notice any activity there, so a crystal/rf/interference issue is not likely. If it was one of those, the motor would go nuts too.
__________________ I-Lap Timing Systems Precision Timing for Small Scale Motorsports www.rclapcounter.com
