Old 2015.10.31, 09:27 PM   #1
sangyue
Compatible KO PROPO FHSS Micro 4CH Receiver
Found a KO PROPO FHSS compatible receiver unit on Banggood.com. Banggood SKU301297.
http://www.banggood.com/2_4GHz-KO-PROPO-FHSS-4CH-Receiver-Unit-Compatible-With-KO-PROPO-EX-1EX-2-Transmitter-p-1009388.html
Description:
This module is designed for KO PROPO FHSS protocol transmitters.
It supports the Ultra Response mode of KO PROPO EX-1 and KO PROPO EX-2 Transmitters, RF-903FH and RF904FH modules. It offers 4-channel support in a compact size!
For best performance, digital servo must be required.
Size: 21.5mm x 18mm
Power: 3.7-12V DC
Compatible Transmitter:
KO PROPO RF-903FH/RF-904FH
KO PROPO EX-1 FHSS
KO PROPO EX-2
Features:
1. 4CH Support
2. Performance CPU enhance precision control feeling
3. Ultra response mode [KO] support
4. Tiny compact size
Package Included:
1 x 2.4GHz KO PROPO FHSS Receiver
sangyue is offline   Reply With Quote
Old 2017.05.02, 09:41 AM   #2
Guidok
With this receiver they say it's "designed for KO PROPO FHSS protocol transmitters"
https://www banggood.com/2_4GHz-KO-P...p-1009388.html
Does that mean it only works with ko propo fhss transmitters, or does it also work with generic fhss transmitters like a FlySky iT4/absima cr4t?
Or should I use a different fhss reciever like a FrSky VD5M 2.4Ghz 5CH Micro Receiver, which is also pretty small:
https://hobbyking com/en_us/frsky-vd...y-capable.html
Guidok is offline   Reply With Quote
Old 2017.05.02, 01:10 PM   #3
If you are working with a "sports" series Mini-Z chassis then the IT-4 or Kyosho 432P transmitter will bind directly with the chassis. Either radio has separate protocols for FHS and FHSS.
Old 2017.05.04, 01:45 AM   #4
Guidok
No I'm planning to buy an atomic BZ 2017 which comes with no tx/rx, so I need a small rx that works with a flysky transmitter (or absima cr4t transmitter, those are clones).
The absima cr4t works confirmed with kyosho sports series (with some software settings altered)
Or should I go for one of these when I want to use a FlySky FS-iT4/absima cr4t transmitter:
https://www banggood.com/DasMikro-FL...p-1066770.html
https://www.banggood com/Mini-Flysky...p-1097424.html
these digital protols are pretty confusing.
Old 2017.05.04, 05:41 AM   #5
I would think that the first thing to do is select the transmitter. Once done then proceed to receiver choices. Though I have not experienced it, I have heard of range issues with the Das Mikro units as well as the bootlegged Gogolap clones.
FS: KO Propo 2.4 GHz Module & Receiver Bundle for EX-10 Helios Mrs Mini-Z Mini-ZRacer.com Direct Marketplace 0 2012.11.20 12:41 PM
Airtronics MX-3 2.4 FHSS Compatible? Samael76 Transmitters, Receivers and Crystals 2 2010.02.03 04:09 AM
Micro Indoor 4ch Helicopter benmlee Off-Topic 4 2007.09.30 09:05 PM
Personal lap timer counter CHEAP! 46u Lap Timing Systems and Software 10 2006.02.14 03:50 PM
Micro RS4 RTR Review pkh Mini RC 7 2002.10.11 09:34 PM
