Old 2002.02.05, 12:34 AM   #1
dugrant153
Drifting Mini Zs?
Is it actually possible to drift Mini Zs like Initial D style?
dugrant153 is offline   Reply With Quote
Old 2002.02.05, 12:37 AM   #2
Russ
Super Moderator
Russ's Avatar
go to my site, link is at the bottom of my post...go to the videos section, and it should be the 2nd video from the top...it's my drifting video...check it out....
Russ
Old 2002.02.05, 01:29 AM   #3
hey russ...
cool video... liked the music from hardknox as well...
checked out your other video's at the skatepark as well... cool
Old 2002.02.05, 09:53 AM   #4
Russ
Super Moderator
Russ's Avatar
Thanx!! The drifting video was my first attempt at digital merging/editing/cutting. The Skatepark Highlight video process came to me a little better. Thanks though, means alot!!!
Russ
Old 2002.02.05, 10:49 AM   #5
Wedginator
hey, try my site the movies section..... it's a 6mb movie with no sound, but you can see some pretty cool drifting moves....
Old 2002.02.07, 11:03 PM   #6
dugrant153
Do you guys use certain drift setups?
Old 2002.02.07, 11:19 PM   #7
Russ
Super Moderator
Russ's Avatar
well, not really. The car in my video was just a plain-stock mini-z. I've drifted my hopped-up Z, and it has a little bit more control, but probably mostly due to the softer tires.
Learn it stock first, then build your skills as you build your Z
Russ
Old 2002.02.07, 11:27 PM   #8
Wedginator
i agree with russ...
Old 2002.02.09, 11:53 PM   #9
dugrant153
Sounds very cool.
Another question: What is the ideal terrain (or conditions) to drift a mini Z? What kind of floor? And will hard tires on linoleum give some good drifting?
Old 2002.02.10, 12:02 AM   #10
Russ
Super Moderator
Russ's Avatar
So far, the best luck I've had is on my hardwood floor, but it's not very slick. It's pretty old polyurethane, so it's worn down quite a bit. I used stock, crappy hard kyosho tires too.
Russ
Old 2002.02.14, 10:30 PM   #11
dugrant153
I was talking with a friend who knows a lot about cars. In real world drifting, apparently it's easy to induce drift with RR (Rear engine, rear wheel drive) cars.
The Mini Z is RR, right? Does that mean it's easy to induce drift?
Old 2002.02.14, 11:58 PM   #12
mini-z
Administrator
mini-z's Avatar
dugrant153, it's pretty easy with sufficiently bad tires. With practice, I think FR/MR/RR drift are all pretty easy to achieve. For some seriously cool 4WD drift, take a look at our sister site:
http://yourmicro.com/micro_movies.html
Old 2002.02.15, 02:09 AM   #13
PorscheGuy964
House Plant
PorscheGuy964's Avatar
Send a message via AIM to PorscheGuy964
Porsche,need I say more......
My mini-z is an A.I.V.
PorscheGuy964 is offline   Reply With Quote
Old 2002.02.25, 10:10 PM   #14
dugrant153
Well,
I've taken a look at how that Micro RS4 drifts... but that's an AWD car.
The Mini Z is a RWD... how would you begin to induce drift? (Holding it will take practice, for sure).
Old 2002.02.25, 10:14 PM   #15
Wedginator
if u want to drift the Z, u just steer hard in the direction u wanna turn, then when u see the rear lean out, counter steer and ease off the throttle.... make sure that you're on a lower friction surface such as hardwood floor..... if you master it, you can make it drift really nicely and hold it for a while.....
oh, and if you want a drift pic, look at my website in the pictures and movies section.... the top pic is a drift pic. (I appologize for the bad bad bad bad quality....)
BTW, E-mail me if you want the movie.....
First Person Camera in a Mini Z Drifting, cool a$$ video Jebroni Autoscales, Bodies, Cars and Drivers 0 2008.04.01 07:21 AM
Request for Mini Z drifting vids? dugrant153 Videos 15 2007.02.12 06:27 PM
Drifting you Mini Z one2eightd Setups 11 2003.11.29 08:10 AM
