Old 2004.09.07, 05:01 PM   #1
G-Class
Big Slugger
G-Class's Avatar
NiMH Battery Info
I found this great information about NiMH batteries which I think will help answer many questions for newbies and others alike about these batteries. The complete article on this information can be found at:
http://www.rccaraction.com/rc/articles/NiMHbatcare1.asp
1. Which amp rate should I use to charge the batteries?
After initial testing, Jim has settled in on a 5A charge rate for the Trinity team drivers. Though this is a little higher than the rate recommended for average users, he's comfortable that it doesn't harm the batteries. He has tested at higher rates (up to 9 amps!) but found higher rates unproductive.
As with all rechargeable batteries, higher charge rates work the cells harder. The higher rates don't appear to have any positive effect on performance, so stick to the lower rates; 3 to 5 amps is best. Back to the Top
2. Which type of charger should I use?
Almost any style of peak charger can be used to charge NiMH batteries, but caution must be exercised when using less sophisticated peak-detection chargers not specifically designed for NiMH batteries. Voltage peak chargers are designed to look for a certain voltage drop to indicate that a pack has reached maximum capacity. Ni-Cd batteries exhibit a greater voltage fluctuation during the charge cycle and a more noticeable voltage drop at the end of it. Chargers originally designed for charging Ni-Cd packs look for a comparatively pronounced voltage drop before they shut off the charger. NiMH batteries are more stable while being charged and demonstrate less voltage drop when full capacity has been reached. This makes it harder for a Ni-Cd-type battery charger to know when a NiMH pack has peaked. As a result, some of the less expensive, non-adjustable voltage peak chargers will over-charge a NiMH pack. Back to the Top
3. I only have a mechanical timed charger.
Can I use it to safely charge NiMH packs? Yes, but use caution. Continuously monitor the pack's voltage with a voltmeter to determine when it's approaching a full charge, and vigilantly check its temperature. As soon as the pack starts to get hot (this happens rather quickly as it reaches maximum charge), remove it from the charger. It's a good idea to monitor the pack's temperature even if you do have a peak charger; as noted above, the charger can overcook your pack if it is "looking for" the deeper voltage drop of a Ni-Cd pack to indicate a full charge. Back to the Top
4. My charger has adjustable voltage peak detection; which setting should I use?
Chargers that have adjustable voltage peak detection should be set at 0.02 to 0.03 volt voltage drop (for the whole pack) before peak detection triggers and shuts off the charger. Jim has even tried setting his charger to 0.01 volt with good results, but he warns that such a low setting can lead to a "false peak."
Jim also reminded us that we should expect the NiMH batteries to be a little warmer than Ni-Cd cells when they've reached full capacity. When testing with a thermal peak-charger, Jim noticed Ni-Cds were at 35 to 37 degrees Celsius (95 to 99 degrees Fahrenheit) at full capacity, whereas the NiMH batteries were at 40 to 45 degrees C (104 to 113 degrees F). Keep in mind that this is the temperature as detected by the thermal probe, not by your hands. The actual temperature of the battery is likely to be a little higher. Thermal peak charging is a very useful alternative to voltage peak detection, as it simply looks for a significant change in pack temperature. It's an excellent charging method, though it would be wise to activate the maximum charge time function in chargers so equipped to act as a backup in case the thermal probe is accidentally separated from the battery pack. Back to the Top
5. Which charge mode should I use?
Many of the charge modes originally intended to increase the performance of Ni-Cd batteries are proving to be detrimental to NiMHs. Irrespective of the brand of charger, the results always appear to be better when the Panasonics are charged in a linear mode, meaning there is no programmed fluctuation in amp rates and/or polarity. The special charge modes don't seem to negatively impact run time, but the pack's voltage is slightly lower. Bottom line: use linear charge modes when using a charger that offers that choice (it's the default mode for most high-end peak chargers and the only mode available on lower-priced units). Back to the Top
6. Will trickle-charging help or hurt my NiMH cells?
Trickle-charging should be avoided when charging NiMH packs. Most chargers default into a trickle mode when fast charging has been completed. This mode was designed to keep Ni-Cd packs at their highest voltage until they were used, but it seems to have a "flattening" effect on the Panasonic cells. If your charger's trickle-mode can't be turned off, just be sure to disconnect the pack from the charger as soon as it's peaked. Back to the Top
7. Should I re-peak my pack before a race?
Yes. For maximum performance, have the pack "peak" minutes before a race, stuff it into your car and go racing. However, using this method leaves no margin of error for a false peak; a safer approach would be to start charging about 1 hour before a race. This will leave 40 to 45 minutes to charge the pack, and you'll have an extra 15 minutes or so to remedy a false peak, if you need to. If all is well, then you can simply re-peak the pack prior to placing your car on the track. The ideal is to avoid letting the pack sit in a state of full charge for longer than necessary. Back to the Top
8. How should I discharge a NiMH pack after a race?
NiMH batteries seem to be far less sensitive to post-race treatment than Ni-Cds are. Trinity team guys discharge their packs by running them out in the car or placing them in a discharge tray. Their routine varies according to when a pack will next be used. If it will be used within a week, Jim recommends that you take it down to 0.9 volt per cell, or 5.4 volts in a 6-cell pack. He also says the rate of discharge doesn't seem to impact pack performance. NiMH cells don't have the same memory characteristics as Ni-Cds, so it seems less important to follow strict discharge guidelines. By whichever means necessary, bring the pack down to 0.9 volt per cell, but no less. NiMH batteries don't respond well to being stored in a completely discharged state. If a pack is at a nearly zero discharge state and is put away for a week, it can easily bleed off the remaining charge and reach dead zero. If the pack is allowed to bottom out, it could be harmed.
If a tray is your chosen discharge method, the pack will have to be removed earlier than is typical with Ni-Cds. Remember, discharge trays designed for Ni-Cds will bring voltage well below what's considered safe for NiMH batteries. Back to the Top
9. What about long-term storage?
If the batteries are to be stored for more than two weeks, Jim says it's wise to charge them to at least 50 percent of capacity. All rechargeable batteries lose their charge if left unused for long periods—a condition we already know isn't ideal for NiMH batteries. For lengthy storage, it's best that packs have a significant level of charge. A note for those who use battery "bugs," or cutoff devices: if they're designed for use with Ni-Cd batteries, they will discharge a NiMH pack to below a safe level. Seek out a device that's intended to be used with NiMH packs. With all of the information already, it should go without saying—but I'll say it anyway—that you should never store packs with a dead-short lead. Back to the Top
10. Can I run a pack of NiMH batteries more than once a day?
Yes; in fact, it's recommended. After a week of being stored, a pack's first run will tend to be "flat," and it will develop more punch during its second and third runs. You simply need to let the pack cool completely before you recharge it. Even the Team Trinity drivers have run the packs two and three times during a day.
Mercedes Benz G55 AMG, Black, X-Speed motor, Titanium 10-34t, High Grip Tires Type B, spare tire mounted on the hood.
My Gallery NEW OL PICS UPDATED:07/27/2006
"There's a momentary pause while a Nomex finger stabs at any button relating to safety." Top Gear Magazine FEBRUARY 2007
G-Class is offline   Reply With Quote
Old 2004.09.07, 05:26 PM   #2
TNB
Pet Human
TNB's Avatar
Below are some links to info on battery types, charging, discharging, and caring for batteries. Unlike the post above, I wouldn't even consider charging AAAs at 5 amps or even most batteries at 9 amps unless they were given to me and I could trash them after a race.
http://www.onlybatterypacks.com/qa.asp
http://www.teamnovak.com/Tech_info/t...rge/index.html
http://www.teamtrinity.com/tips/batts.asp
http://www.competitionelectronics.com/tech%20tips.html
Gallery TNB
Old 2004.09.08, 03:38 PM   #3
El Tigre
I charged a AAA pack once at 4 amps accidentally and it vented and spewed a big mess all over my workbench.
El Tigre is offline   Reply With Quote
Old 2004.09.08, 03:45 PM   #4
TNB
Pet Human
TNB's Avatar
I know people who have charged AAAs at 3 amps. "Toasty", but they planned on trashing them afterwards anyway. I usually just charge around 1.0-1.2 amps.
Gallery TNB
Old 2004.09.08, 08:32 PM   #5
PTRacer
Ultimate Racer
PTRacer's Avatar
Don't forget that the 5a charge currente is for sub-c cells. That is way to much for our AAA Ni-Mh...
PTRacer is offline   Reply With Quote
Old 2004.09.09, 11:29 AM   #6
G-Class
Big Slugger
G-Class's Avatar
I think this article was mainly written for larger RC's like electric monster trucks, touring cars, etc. Thanks for the clarification. Hopefully, some of this info is of some value to some of us.
Lacrosse BC-900 Alpha Power Battery Charger arch2b Batteries, Chargers and Dischargers 41 2007.10.24 07:25 PM
Maha MH-C9000 WizardOne Charger-Analyzer for 4 AA / AAA rkk Batteries, Chargers and Dischargers 51 2007.08.02 04:49 PM
Another Post on Batteries: Clearing up some confusion??? Spoon Batteries, Chargers and Dischargers 21 2007.03.02 05:28 AM
Alkaline VS. Ni-Cad G-Class Beginner Questions 12 2004.07.24 02:21 PM
GP Nimh rechargeable battery question pwong Parts and Hop-ups 13 2001.12.14 09:28 PM
