Go Back   Mini-ZRacer.com Forums > Events > Mini Cup USA 2005
View Poll Results: Expert/Super stock
Kyosho chassis only 8 66.67%
Any chassis, mini-z dimensions (Iwaver, proz...) 4 33.33%
Hard shell bodies (iwaver, kyosho...) 10 83.33%
Any body 3 25.00%
4 - AAA rechargable cells 11 91.67%
4.8 volts, any cells 1 8.33%
Kyosho stock motor, racer provided 6 50.00%
Handout stock motor, track provided (could be any brand determined later) 6 50.00%
Stock sized wheels, rubber tires, offset must fit under the body 7 58.33%
Any wheel, rubber or foam tires, offset must fit under the body 6 50.00%
Multiple Choice Poll. Voters: 12. You may not vote on this poll
Old 2004.12.24, 10:35 AM   #1
brian
stock class poll
I believe this will actually be two classes, a novice/box stock class and an expert/super stock class (even though this is a year worth of racing, novices should be able to compete but may not be able to win a class within this time)
Box stock seems to be fairly decided with
Kyosho Chassis, no modifications to the chassis, electronics or motor, no bearings, no ball diff, plastic h-plate
4 - AAA rechargable cells (no mah, 850 is enough for 30 minutes anyway)
Gearing changes are allowed
Kyosho radio must be used
The expert stock class is a bit more complicated with non-kyosho cars allowed, because of this I propose that we allow any chassis or mods.
This class assumes any radio could be used but with unmodified electronics (speedcontrol/receiver) from an iwaver or kyosho car
brian is offline   Reply With Quote
Benefits of using a stock diff? Programmers Mini-Z Science 12 2007.08.05 04:06 PM
HFAY Stock Motor Question LBRC How Fast Are You? Online Points Series 14 2007.07.02 02:30 PM
Mini Cup Usa 2005 National Championship THRC Dan Mini Cup USA 2005 96 2005.10.26 08:42 AM
A new Stock Car class will be starting this fall at CP Mini RC Raceway Blackno3 CP Mini RC Raceway, NY 58 2004.10.27 08:23 PM
remote and stock parts for sale BoyWonder Miscellaneous Discussion 0 2003.03.10 08:02 PM
