Go Back   Mini-ZRacer.com Forums > General Discussion > Setups
Old 2005.01.08, 11:55 AM   #1
PoorZDriver
I Apex Like poop
CAMBER ADJUSTMENTS? anyone know of knuckles?
does anyone know of high quality delrin knuckles that would offer a -1deg camber? this would really help my right side tire wear, but i will also have to have a 0 deg for the left, are there camber sets?
i get about 1 deg of tire wear (camber) on the outside tire (right side) and when it wears to that angle is when my car seems to handle the best, i was thinking if i put a o deg camber knuckle on the left (for the sake of matching kingpin slop) and a -1 deg on the right, i will handle alot better with new tires and it will take them alot longer to wear since they will wear evenly. so i need to find derlin, or aluminum camber adjusted knuckes, in 0 and 1 deg, i may even try 2 and see how that goes
Setup:
Currently Mr-02 RML
Eagle ball diff
Kyosho carbon soft H plate
CP bearings
FERR F50 wheel set (shattered at this time, aluminums in today)
MR-01 green spring in front right, MR-01 red in front left
15 deg radials in rear
30 deg lo-pro in front
Kyosho Oil damper
X-speed motor with 8t
ATTN SHOP OWNERS!
I will trade professional graphic design and photography services in part or whole for Mini-z's and parts. Pm me for details
PoorZDriver is offline   Reply With Quote
Old 2005.01.08, 12:13 PM   #2
TITANIUM
ready to race...
TITANIUM's Avatar
the shop here has a bar that goes on the mr-02 chassis that has chamber and/ castor also.....i have one and like it...the gold one has both camber & castor the blue one only has chamber.....i think? but anyway
http://mini-zracer.com/shop/product.php?pid=1088
TITANIUM is offline   Reply With Quote
Old 2005.01.08, 12:17 PM   #3
TITANIUM
ready to race...
TITANIUM's Avatar
p.s. this bar really helped with tire wear...but i had to go up to a hard spring to cut out some bit the tire was getting....in other words it went into a oversteer condition.....and i adjusted with harder springs to bring it bach to a happy medium...
Old 2005.01.08, 12:19 PM   #4
PoorZDriver
I Apex Like poop
then you have to do both sides, and looking at the car, i dont quite see where it goes, do you have to cut the factory kingpin arms? i wish there were knuckles so i can do the 2 sides diff.
ATTN SHOP OWNERS!
Old 2005.01.08, 12:38 PM   #5
TITANIUM
ready to race...
TITANIUM's Avatar
there are knukles out there...i have a few diffent types, i got them from another shop...sorry mzr...
anyway...i just thought you would find those parts interesting......
Old 2005.01.08, 12:44 PM   #6
i have one of these as well and really like it.
here are some pictures
Old 2005.01.08, 12:57 PM   #7
PoorZDriver
I Apex Like poop
what are the knuckles you have arch? are they toe adjustments?
ATTN SHOP OWNERS!
Old 2005.01.08, 01:51 PM   #8
those are 1 deg whatever gpm knuckles. toe in/toe out is done with tie bars, not knuckles.
unless your picky about color i would get k. alloy stuff as it's clearly higher quality but doens't offer the color range of gpm
Old 2005.01.08, 02:11 PM   #9
PoorZDriver
I Apex Like poop
so the knuckles you have are either camber or caster, your not sure?
ATTN SHOP OWNERS!
Old 2005.01.08, 02:30 PM   #10
caster i believe.
Old 2005.01.08, 02:35 PM   #11
Capt. Oversteer
Capt. Oversteer's Avatar
i hope to see one made for the new 015 chassis!!!
You can never turn too soon or too sharp
Capt. Oversteer is offline   Reply With Quote
Old 2005.01.08, 03:32 PM   #12
Big_L
Knuckles are for the camber.
Tie bars are for toe in/toe out.
Tower bars depending which one you get:
1) 0* camber
2) 1.5* camber and 0.5* caster
I believe they should work with the MR-015 chassis, because the steering set up is the same as the MR02.
Big_L is offline   Reply With Quote
Old 2005.01.08, 04:41 PM   #13
PoorZDriver
I Apex Like poop
1) 0* camber
pretty sure i have only seen knuckles for caster, but i will look more
ATTN SHOP OWNERS!
Old 2005.01.08, 05:51 PM   #14
TITANIUM
ready to race...
TITANIUM's Avatar
BIG L has it correct.
Old 2005.01.08, 06:33 PM   #15
i'm sure he is but as gpm is well known for mislabeling parts. if you check , they list all the knuckle sets as caster
what is camber and caster? herman Setups 1 2008.03.27 10:38 PM
question about camber knuckles and tie rods?? tada Mini-Z AWD MA-010, MA-015 7 2006.07.18 01:02 PM
increase camber and toe-in with stock knuckles aznracer2003 Mini-Z Racer MR-02 9 2004.10.15 11:58 PM
Front Knuckles with Camber.. Straywalker Mini-Z F1 MF-010, MF-015 7 2002.09.10 12:43 AM
