Old 2005.03.18, 09:45 PM   #1
Vital Statistics
Everyone wants a better shop, Mini-z is comitted to developing one. We are asking for member participation in the collection of vital statistics for every mini-z.
with the recent purchase of the mustang autoscale, i noticed for the first time kyosho is providing post card sized pamphlets with the vital statistics for that autoscale. as this is a new feature, we would like to apply it retroactively to all the previous autoscales as we believe this information will be of great benifit to anyone who ever searched the shop.
in the interest of being as brief and to the point we have reduced the amount of information to the following:
(filled in for example)
ASC part number(s): MZG205MB / MZG205MG
RTR part number(s): 30461
Type of chassis: MR-02 MM
Wheelbase: LL
Suspension limiter: 5
Wheel set part number: MZH215S
Front wheel width: N
Front wheel offset: 0mm
Rear wheel width: W
Rear wheel offset: 1mm
Front chassis width: 70mm
Rear chassis width: 72mm
Receiver antenna D size: 30mm
if you have require clarification on what we are asking for, i have attached the card that was supplied with my mustang as an example.
if you received one of these cards with your readyset or autoscale, please post this information.
if your really bored, you can find alot of this information in existing documents such as your manual, autoscale pamphlets and kyosho pdf's you can download such as the wheel chart.
the more submissions we have, the better you and others will be informed whe searching the shop.
PLEASE, only post this info.
Old 2005.03.20, 05:31 AM   #2
HammerZ
Master of Thrash
HammerZ's Avatar
I did one for the Lancia Stratos, because it is somewhat unusual. There are a few N/A's in the listing, and added the motor position to the list. I am suprised it is listed as low. I also made the list into a text file template that can be used to fill out.
Lancia Stratos
ASC part number(s): MZC16MC/ MZC16SR
RTR part number(s): 30134
Type of chassis: MR01
Wheelbase: S
Motor mount position: Low
Suspension limiter: N/A
Wheel set part number: MZ26
Rear wheel width: W
Rear wheel offset: 0mm
Front chassis width: N/A
Rear chassis width: N/A
Receiver antenna D size: 15mm
File Type: txt ASC Info Template.txt (291 Bytes, 62 views)
Old 2005.03.20, 08:19 AM   #3
HammerZ
Master of Thrash
HammerZ's Avatar
I didn't list the limiter, because the 01 don't have them. The width I riffled through five different sheets and did not find that listed anyplace. If I had to guess, I'd say front 65mm, rear 70mm.
Old 2005.03.20, 08:49 AM   #4
HammerZ
Master of Thrash
HammerZ's Avatar
I guessed on the chassis width again. These two had the cards with them. I am still looking for others.
Lotus Europa.
ASC part number(s): MZG40G/ MZG40BK/ MZG40CW
RTR part number(s): 30358
Type of chassis: MR01F
Wheelbase: M
Wheel set part number: MZH104C
Tire set part number: MZT100C-F
Rear wheel width: N
Front chassis width: 65mm
Rear chassis width: 65mm
Receiver antenna D size: 20mm
McLaren F1
ASC part number(s): MZG203
RTR part number(s): 30457
Type of chassis: MR02 MM
Wheelbase: LL
Wheel set part number: MZH213
Rear wheel width: W
Rear chassis width: 70mm
Receiver antenna D size: 5mm
Old 2005.03.20, 09:21 AM   #5
HammerZ
Master of Thrash
HammerZ's Avatar
This one I used a sheet from my white body set. There are some holes in this.
R32 Skyline GT-R
ASC part number(s): MZB23
RTR part number(s): N/A
Wheelbase: L
Motor pod setting: Low
Wheel set part number: MZ40/ MZ41GM
Front wheel offset: 1.5mm
Rear wheel width: W
Rear wheel offset: -1mm
Receiver antenna D size: 35mm
Ferrari F40
ASC part number(s): MZB19
Wheelbase: M
Wheel set part number: MZ30
Front wheel offset: 2.5mm
Rear wheel width: W
Rear wheel offset: 2mm
Old 2005.03.20, 09:31 AM   #6
thanks for your efforts hammer. i guess not to many others have the time or inclination to contribute.
obviously not all the info can or could be found on some of these so there enevitabley be some holes but over time i'm sure they will be filled.
motor position is applicable to mr-01's which are no longer marketed by kyosho. the move to the mr-015 eliminates the need for motor position execpt for those very few mr-01's that require the high mount which can be noted by whomever posts the info.
ok, we can't let hammer get them all can we there are tons of bodies nad tons of members.... if we could even get each to do just one we would have them all very quickly. ofcourse those like hammer make it much easier please contribute and other than my ramblings, lets keep the posting applicable to the information, follow hammer's example
Old 2005.03.20, 09:47 AM   #7
HammerZ
Master of Thrash
HammerZ's Avatar
The Lancia body is one of those that has you wondering if you need the pod high or low. According to the listings it said low. It has to be by far the tightest Kyosho body I have seen for a Mini Z chassis. If it helps out with the shop listings, I am behind it %110.
Old 2005.03.20, 12:27 PM   #8
Ninja
Mechanic
Ninja's Avatar
i dont know if you guys wanted OL's to be listed here or not, but here is the info for the ones i have seen info for, i will get around to posting the ones for my racers once i find the books on them.
Body Name MITSUBISHI PAJERO
ASC part number(s): MVC1HM(#201), MVC1JK(#200), MVG5W(STREET WHITE), MVG5R(STREET RED)
RTR part number(s): 30261HM(#201), 30261JK(#200), 30265W(WHITE), 30265R(RED)
Type of chassis: OL
Wheelbase: B1
Suspension limiter:
Wheel set part number: MVHO1(WHITE), MVHO1AM(ALUMINUM), MVHO1CM(CHROME), MVH03(STREET)
Rear wheel width: N
Rear chassis width:
Receiver antenna D size: 13MM
Body Name BMW X5
ASC part number(s): MVG3S(SILVER), MVG3MB(METALLIC BLUE)
RTR part number(s): 30263S(SILVER), 30263MB(METALLIC BLUE)
Type of chassis: OL
Wheelbase: B2
Suspension limiter:
Wheel set part number: MVHO4
Rear wheel width: N
Rear chassis width:
Receiver antenna D size: 17MM
Body Name TOYOTA LAND CRUISER
ASC part number(s): MVC2JR(#239), NVC2S(SILVER), MVC2PW(WHITE)
RTR part number(s): 30262JR(#239), 30262S(SILVER), 30262PW(WHITE)
Type of chassis: OL
Wheelbase: B2
Suspension limiter:
Wheel set part number: MVH02R(RED), MVHO2AM(ALUMINUM), MVHO2CM(CHROME)
Rear wheel width: N
Rear chassis width:
Real Racers Do It Sideways.
Old 2005.03.20, 01:59 PM   #9
we are asking for submissions for ALL mini-z's
thanks for your help ninja between the two of you we should get a nice chunk of them out of the way i really appreciate the effort
Old 2005.03.20, 08:27 PM   #10
lfisminiz
lfisminiz's Avatar
Red face
Ill have to do some digging. All the bodies i get i ussually throw that stuff. I guess i should check it out better.
Old 2005.03.20, 08:30 PM   #11
i've tossed all mine too, thus the reqest for submissions
Old 2005.03.20, 08:54 PM   #12
HammerZ
Master of Thrash
HammerZ's Avatar
The funny thing is earlier I was looking for the stats on the Diablo, the papers that came with it it didn't even have it listed (it listed the McLaren). I would have had it listed here too.
The part numbers on the F40 and R32 above is the white body sets, so they need the right ASC numbers.
Old 2005.03.21, 12:36 PM   #13
HammerZ
Master of Thrash
HammerZ's Avatar
Two more older ones that I found stuff on. I figure incase there is a rerelease of these. I wished I can go back and edit the others, to add numbers and such. Cross referance it with the wheel chart, some of these may have more than two/ three part numbers for them.
Nissan Skyline R34 GT-R V Spec
ASC part number(s):
RTR part number(s): 30931S/ 30931MB/ 30931R
Wheelbase: L
Wheel set part number: MZ13/ MZ13C/ MZ13GM
Rear wheel width: N
Honda S2000
ASC part number(s): MZC8
RTR part number(s):
Type of chassis:MR01
Wheelbase: M
Wheel set part number: MZ22
Rear wheel width: N
Receiver antenna D size: 23.5mm
Old 2005.03.21, 12:59 PM   #14
go ahead and post the information as updates (only the updated info) and i'll see abnout getting the edit feature fixed
Old 2005.03.21, 01:31 PM   #15
HammerZ
Master of Thrash
HammerZ's Avatar
Some more of the old MR01 cars. I found these mucking through some old PDF files on my system.
Mitsubishi Lancer Evo. VI
ASC part number(s): MZC3
RTR part number(s):30041R/ 30041S/ 30041W
Wheelbase: M
Wheel set part number: MZ15/ MZ15CM
Rear wheel width: N
Subaru Impreza WRX
ASC part number(s): MZC2
RTR part number(s): 30932BK/ 30932MB/30932Y/ 30932W
Wheelbase: M
Wheel set part number: MZ14GL
Rear wheel width: N
BMW Z8
ASC part number(s): MZC4
RTR part number(s):
Wheelbase: L
Wheel set part number: MZ16
Rear wheel width: N
Audi TT
ASC part number(s): MZC5
RTR part number(s):
Wheelbase: M
Wheel set part number: MZ17
Rear wheel width: N
Porsche 911 GT3
ASC part number(s): MZC6
RTR part number(s):
Wheelbase: M
Wheel set part number: MZ21
Rear wheel width: N
Dodge Viper GTS-R
ASC part number(s): MZC7
RTR part number(s):
Wheelbase: M
Wheel set part number: MZ20
Rear wheel width: N
XRL Regoinal Championship for Xmods" ppl Who are entering" put statistics of ur xmods Hondatunerz2002 Mini RC 16 2004.07.15 04:50 PM
