Old 2002.03.11, 07:45 AM   #1
mryung
Send a message via ICQ to mryung
Double/Triple FET installed in the PCB
In Hong Kong, many Mini-Z players do "operation" on the PCB of Mini-Z by doubling /tripling the FET "the chip 3004 on the PCB". There are 4 FET 3004 on the PCB for FD, BK, LT and RT. We will double / triple the FET 3004 near the motor output connection, instead of installing the twins turbo. Why? It is because it make the Mini-Z run with linear acceleration and higher top speed. It is much better than twins turbo which only give u a crazy beginning torque but no improvement on the top speed.
Some body also remove the original FET 3004 and then replaced by another FET like FET 3006 or even FET made by different manufacturer.
Thomas
A Mini-Z player in Hong Kong.
mryung is offline   Reply With Quote
Old 2002.03.11, 04:36 PM   #2
NOMOTORLIMIT
nomotorlimit@hotmail.com
NOMOTORLIMIT's Avatar
Has anyone installed an actual servo on their mini Z over there in Hong Kong? As far as the extra fets, I believe it. I saw a big difference when I changed the internal circuitry. now I can use any motor I want. Even a 10th scale motor, if it will fit.
http://www reflexracing net
Old 2002.03.11, 04:46 PM   #3
PITZON
MR 02 Driver
PITZON's Avatar
Send a message via ICQ to PITZON
Any pics? Or further info? I really want to try this
Micke Pitzon....
Check out some of my cars http://mini-zracer com/gallery/pitzon
PITZON is offline   Reply With Quote
Old 2002.03.11, 05:13 PM   #4
NOMOTORLIMIT
Yeah, it is under parts and hop-ups. The title is WORLD's FASTEST MINI Z.
Old 2002.03.12, 09:43 PM   #5
jagr
jagr's Avatar
Send a message via ICQ to jagr
can anyone explain how this works
i don't see how putting 2 FETs will give a higher speed because the output voltage level will still be the same compared to using an external turbo which will be able to give an output voltage level close to what 4 batteries can give. However I believe that torque will increase
jagr is offline   Reply With Quote
Old 2002.03.12, 11:08 PM   #6
mryung
It is because the original ESC will burn if a high current demanding motor like Tamiya Plasma, Jet Dash, Hyper Dash and hand wound motor, for examples, is used. Double FET or Triple FET can increase the capability of Mini-Z ESC for high current demanding motor.
Thomas
Old 2002.03.12, 11:14 PM   #7
jagr
jagr's Avatar
Ok so installing double FET will not allow not have any performance improvement if you use the original motor?
Old 2002.03.12, 11:22 PM   #8
Wedginator
check out http://www.minizhobbyshop.com, they explain a bit about FET upgrades....
Old 2002.03.13, 08:35 AM   #9
wamshoff
Mini-Z Novice
you can also look at
http://mini-zracer.com/forums/showth...?threadid=1498
wamshoff is offline   Reply With Quote
Can Iwaver PCB Damage Coz not have FET? minircw iWaver 14 2008.04.20 10:38 PM
MR-02 PCB FET Upgrade Problem. Hammer Mini-Z Racer MR-02 12 2007.09.17 01:55 AM
AWD PCB Gone Wild after Fet Upgrade! ub0211042 Mini-Z AWD MA-010, MA-015 49 2007.07.13 02:52 PM
PCB FET pads Psyklops Mini-Z Science 26 2002.11.14 12:46 AM
