Old 2005.10.20, 02:04 AM   #1
james399
home made low rider shocks tutorial..
i wanted to lower my OL... but I didn't want to buy another set of shocks... so i was looking at the low rider shocks, and it seems the only thing different about them was that the screw shaft was shorter....
so here it is...
picture 1 and 2 are of supplies needed, 1 screw driver, 1 plastic coffee stirring straw, and a razor blade...
cut the plastic straw to desired lenght of lowering.... carefully cut four pieces of equal length... or you can leave the rears stock or a little bigger if you want a forward slammed look...
then take apart a stock shock... insert screw into plastic tube piece, and reasemble
it should now be shorter than a stock shock...
check out the picts its all pretty straight forward...
james399 is offline   Reply With Quote
Old 2005.10.20, 02:06 AM   #2
james399
the rest of the picts
Old 2005.10.20, 03:02 AM   #3
byebye
byebye's Avatar
Can you take a picture of the screw mounted in the shock?
-Byebye
Old 2005.10.20, 03:31 AM   #4
james399
-Byebye
not sure what you mean by that...
but here are some picts of the entire assembly of the shock...
also one of the picts above (its kind of dark) but it is a stock shock next to a lowrider shock...
Old 2005.10.20, 03:31 AM   #5
james399
one last pict
Old 2005.10.20, 05:53 AM   #6
byebye
byebye's Avatar
Thanks j399. That's what I was looking for. Good idea and I'll have to try it.
-Byebye
Old 2005.10.20, 10:01 AM   #7
Aron
Aron's Avatar
Cool I have been wanting to look into making some of those but you did a good job and I will just follow your Tut. Thanks for posting.
Aron is offline   Reply With Quote
Old 2005.10.20, 02:00 PM   #8
james399
now i just need my pcb because i dropped my H1 substantially lower than stock lowriders... so im wondering how the lower center of gravity is going to impact the ride...
im hoping it will drift better
Old 2005.10.20, 06:24 PM   #9
HammerZ
Master of Thrash
HammerZ's Avatar
Simple and easy to do. Yes it will drift well, like racing up Pikes Peak. I only have less than a half a millimeter of shock travel like this, so no jumping with it. And I use the shock shaft screws to adjust the chassis for flat running. I will have to put the F150 body on later to see how it looks, I'll need the ASC wheels as these would be in the fenders for sure.
Also for the "racer rake" I used the front shocks in the rear and the rear shocks on the front.
Old 2005.10.20, 09:20 PM   #10
james399
thats awesome, im glad you liked the mod... lol....
im installing a pcb right now... and god damn the steering is ridiculous to install... i keep snapping wires, so i have to keep resodering them!!!
arg....
Old 2005.10.20, 09:26 PM   #11
HammerZ
Master of Thrash
HammerZ's Avatar
The servos are the worst to put together, for me it helps to remove the front box alltogether and assemble it off the chassis. Then when you have the front box together remount it and lay the board in. This is the way I installed my monster electrics, same for the overland just smaller pieces.
Old 2005.10.20, 09:28 PM   #12
so your creating a spacer for the shaft screw at the top mount.... wow, never thought about that. very simple and effective. if you can find flexible tubing you might be able to achieve slighltly less rigid response as well.
Old 2005.10.20, 10:03 PM   #13
HammerZ
Master of Thrash
HammerZ's Avatar
Hmm, needs some of those G wheels. I made my spacers from styrene tubing 3mm od. and 2mm id. I used the white stuff and the screws fit right in without having to drill it out. I did this to my set of lowdown shocks, this way I just swap them out and go.
Old 2005.10.20, 11:04 PM   #14
james399
just destroyed another pcb!!!
after resoddering the wires a few times, the motor attached to the steering servo stopped working....
im soooo angry right now...
grrrr...
Old 2005.10.21, 03:40 AM   #15
kosakxtreem
kosakxtreem's Avatar
buy an iwaver 02 pcb at ******
much cheaper
it fits except the cristal
kosakxtreem is offline   Reply With Quote
home made mini dyno MysterE Motor Tech 10 2004.02.28 08:49 PM
home made discharger jagr Mini-Z Science 9 2002.07.25 01:07 PM
HoMe MaDe DeCaLs alfa r0meo Bodies 0 2002.07.06 05:34 PM
Home made Bumper bar for Toyota Altezza 280T models Slayer Beginner Questions 3 2002.02.05 07:50 PM
Getting Carried away... home made roll shock Draconious Parts and Hop-ups 2 2001.11.28 09:37 PM
