Old 2005.10.23, 07:51 PM   #1
byebye
byebye's Avatar
FET Upgrade two part video
I found the time to shoot some video of me doing a FET removal. I have attached pictures of the FETs after install and of the tip of the soldering iron. Yes I know the installed chips on the board look like arse. The idea is to take your time. Patience is the key to a good clean install. There are also tons of stuff you can do to clean the board up before you start. This was a down and dirty install video I just had to make. I put the car together after the video and ran it on the track. Much better . All of my cars except my first Enzo are done by me.
Thanks for all the positive feed back .
-Byebye
FET upgrade video Part 1: removing the stock FETs
FET upgrade video Part 2: installing the new FETs
-Byebye
Old 2005.10.23, 10:29 PM   #2
saiyan
BooYa!!
saiyan's Avatar
I'll be subscribing to this thread.
My minizracer gallery:saiyan's paddock
Local Club Website: www mini-az.com
Kamehamehaaaaa!!!!!! Rallye racers are the originators of drift Speedchannel on-line rocks!!
saiyan is offline   Reply With Quote
Old 2005.10.23, 10:49 PM   #3
bda52
I want my two dollars!!!
bda52's Avatar
Send a message via Yahoo to bda52
Same here and this should be a sticky!!!!
bda52 is offline   Reply With Quote
Old 2005.10.24, 12:09 AM   #4
Ibrake Ifry
how long do you heat up the stock fets for?
from my experience if you heat the board up to much they will lift pretty easily
just my 2 cents
Ibrake Ifry is offline   Reply With Quote
Old 2005.10.24, 01:14 AM   #5
ct-mini
Can't wait till part 2... Keep up the great work....
ct-mini is offline   Reply With Quote
Old 2005.10.24, 02:30 AM   #6
byebye
byebye's Avatar
just my 2 cents
I use a 35w iron and you hit each side and push lightly at the same time. Once the solder on the board is melting you move steady back and forth then it just melts(not breaks) loose then you just push it off the board. You don't want it to cool and stick to other parts.
Time may vary depending on how hot your iron is. I think people are pulling the pads when you pry on the board. If you notice I just push it off with out putting upwards pressure on the pads.
I hope it can be a very useful video to everyone wanting a little cheap speed.
-Byebye
Old 2005.10.24, 02:51 AM   #7
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
Nice video, byebye.
I said in another thread that I use a 30watt iron for FET removal, but I checked and it says 40. and the tip is similar to your "sharpened" version. Desoldering braid really speeds up the process but, just like in your vid, letting the iron do the work is key.
I look forward to your FET install vid (for me that's the easy part).
Good work.
-Kenichi's Album-
Old 2005.10.24, 05:27 AM   #8
byebye
byebye's Avatar
Originally Posted by Ken Mifune
Nice video, byebye.
Good work.
Thanks!
I think the toughest first is just takin them off without damaging the board. The next toughest is stacking them since a single chip is just 'tacking'.
-Byebye
Old 2005.10.24, 06:15 PM   #9
Twenty-Se7en
Rockin Da Z
Twenty-Se7en's Avatar
This is one of those additions to a fourm that makes a member great. Everyone and their dog wants to see ByeBye do a fet mod. From the GTGs we all have the idea that he is god of fets... now we know.
Old 2005.10.24, 06:41 PM   #10
Supraman93
byebye,
Excellent video and you make it look so easy. Can't wait to see part 2 and it might just give me enough courage to try a 4x4 oblique stack again without lifting the pads.
Supraman93
MR-02 Enzo 4x4 fets SSV.3
MR-02 Diablo 4x4 fets Plasmatomic
MZM 3x3 fets Anima, Li-Ions
Supraman93 is offline   Reply With Quote
Old 2005.10.24, 06:55 PM   #11
bolter9
How're YOU doin?
bolter9's Avatar
Send a message via Yahoo to bolter9
Damn...I should've had some hip music going in the background- maybe that's why I lifted my pads
Thanks for taking the time to put that together!
Havin' a good one!
My Gallery
bolter9 is offline   Reply With Quote
Old 2005.10.24, 07:23 PM   #12
byebye
byebye's Avatar
Hey guys! Thanks for the positive feedback. Any helpful hints and ideas are welcome. You've all encourage me to iron man it tonight and put the part 2 vid together. I'm off (3rd trip) to Bermuda again tomorrow for work. Tonights work will help me get some rest on the plane.
Stay tuned........
-Byebye
Old 2005.10.24, 08:34 PM   #13
bda52
bda52's Avatar
I really have to get a job with you, to be 'forced' to go to Bermuda for work.....
Old 2005.10.24, 09:26 PM   #14
byebye
byebye's Avatar
BDA baby! It's a tough life I know
Well part 2 is up and at the beginning of the thread. Let me know what you guys think!
-Byebye
Old 2005.10.24, 10:16 PM   #15
bda52
bda52's Avatar
Awesome work Bye-bye. That gives me alittle more confidence to attempt it myself, though I think I will try it on my old IW02 before messing with the MR-02s.
Best all around Stock Motor to use without Fet upgrade Warchild Motor Tech 37 2005.11.07 09:33 AM
Do Trubo or FET upgrade??? matrix Parts and Hop-ups 0 2004.05.17 06:43 PM
Fet upgrade gone wrong overlandkevin Parts and Hop-ups 6 2003.09.23 04:32 PM
FET Upgrade Sky Beginner Questions 1 2003.06.06 10:00 PM
FET upgrade spages West.F1 Parts and Hop-ups 3 2003.01.21 05:12 PM
