Old 2005.10.27, 11:10 PM   #1
james399
XRM stock shock tutorial
ok, ther is no tut on this, so here goes...
basically this will allow you to bolt the xrm shock the same way as a stock shock...
the first picture is showing what it should look like when your done...
open the rest of the pictures in order, and there are detailed arrows and explanations integrated in to the pictures....
and yes it jumps from pict 6 to 9...
if it does not look like the first pict than you did somthing wrong...
if anyone has any suggestions or comments please feel free to add them...
-james
** this is for my peoples in the good ole south K!!!!***
james399 is offline   Reply With Quote
Old 2005.10.27, 11:12 PM   #2
james399
the rest of the picts
Old 2005.10.28, 01:06 AM   #3
Joefullager
Shoot to thrill.
Joefullager's Avatar
Send a message via AIM to Joefullager Send a message via MSN to Joefullager
Nice tut
Joefullager is offline   Reply With Quote
Old 2005.10.28, 01:13 AM   #4
james399
Originally Posted by []D[][]V[][]D
Nice tut
thanx... tutorials are what happens when you're bored nothing to do (my pcb's are still at the shop) im trying to wait patiently, but its hard sitting on your hands...
Old 2005.11.03, 06:58 PM   #5
Schwan43
Good tut. Do those lego tires give you good clearence for the rear diff?
Schwan43 is offline   Reply With Quote
Old 2005.11.04, 04:55 AM   #6
james399
it depends on what your application is... if you are looking to do modest off roading, some decent size rocks or uneven surface.. then yes... personally for me rock climbing or offroading i stick with the super swampers or the xrms, hands down the best... the store has the super swampers in stock, and arch posted somewhere on another thread that there are only 2 sets left... so you might wanna hop on that, if you are looking for maximum ground clearance with the scale look, also rocking these big tires will fry your frets, so you will need to upgrade those... but with the super swampers i can drive my truck through recently cut grass, an impossibility with the lego tires, and stock fets,
the lego tires on the enzo offset wide wheels sticks out a little on the side, and when it is moving the tires look hella scale...
if you check on line you can get these lego tires for about 20 cents a piece... i bought a grip of them for hella cheap... it turns out with enzo rims and lowered, the lego tires are awesome for drifting on rough cement... lots of fun if your into that.... but you eat through the soft rubber when you use it on cement like that....
hope that helps...
-james
Old 2005.12.29, 08:33 AM   #7
Midi^
Midi^'s Avatar
I'm wondering what is the "XRM" and where to get those shocks?
Midi^ is offline   Reply With Quote
Old 2005.12.29, 01:20 PM   #8
james399
xtreme rock machine, also comes with a set of awesome tires... check hobby people on line
Old 2006.02.01, 06:01 PM   #9
turbo1005
can u teach how to do the front shock??
i follow ur step when i do front shock i dont have the same length as the rear shock thx!!
turbo1005 is offline   Reply With Quote
Old 2006.02.02, 03:20 AM   #10
james399
if you look at the bottom of the shock, the stock portion, you will notice, that the shocks on the front, have a longer extension to them...
so the fronts should always be shorter..
if you want them the same length all the way around, you will have to pick up a second set of shocks...
i put the longer ones on the front, to help it hop up easier... softer lesser preload, hope that helps
-james
Old 2006.02.08, 01:25 AM   #11
referjohn
REINSTATED
referjohn's Avatar
james , that tut got me pumped, for less than $6. went to wal....
got xrm, shocks and tires will be used,plus will try to use lightbar for that
scaled look. thanks for the tip
john
Thank You MINI-ZRACER.COM
referjohn is offline   Reply With Quote
Old 2006.02.08, 02:09 AM   #12
james399
john
for less than 6bucks you should have gotten two... lol spare parts are alwys nice...
since the xrm tires are wider than the rim they will look funny, cut the back part off, and you can pop them on and off like hubcaps so it looks more scale....
but be careful, if you do not have stacked FET's you can easiliy fry them using those bigger tires...
-james
Old 2006.02.08, 08:50 PM   #13
james399
john
don't forget to use the front bumper, and to keep the wheels along with the tires to make hubcaps...
-james
My upgrade experience and advices on next upgrades? Aurora Mini-Z Monster MM-01 12 2007.03.07 10:01 AM
DC Setups Thread soulstice Washington DC Area GTG, MD/VA/DC 2 2007.02.22 05:18 PM
GPM Triple Shock & 313A Motor Mount with Xspeed or STock Eddie69 Parts and Hop-ups 2 2002.01.25 11:07 AM
Triple Oil Shock! jcostantino Parts and Hop-ups 5 2002.01.20 12:58 AM
roll shock v. rear shock bbc5 Parts and Hop-ups 2 2001.12.14 04:04 PM
