Old 2006.03.04, 08:58 PM   #1
Spoon
DCGTG FET Guy
Spoon's Avatar
Unhappy Bummed: I broke a knuckle
I was setting up for some Mini-96 Time trials and I lowered my AWD to see how it would handle. Unfortunately I used the Spring spacers instead of the suspension limiters and the car was too low. This made the knuckle sit pretty high up from the rear toe bar. When I put the car into reverse, I clipped the wall.
Since I have the 350 white body on the car, the rear was a little exposed. I heard a crack and my fun with the AWD is over for now.
Fortunately, I ordered some camber knuckles just to try them out and they should be here early next week.
Old 2006.03.04, 09:01 PM   #2
talk about timing good thing you ordered those knuckles
Old 2006.03.04, 11:12 PM   #3
Wavy
Okay, so how does the height affect the vunerability of the knuckles?
Wavy is offline   Reply With Quote
Old 2006.03.05, 04:15 AM   #4
cvctiger
cvctiger's Avatar
Height not the issue
Regardless of the height I found that the knuckles well either be bent or broken with a hard enough impact. That is why I bought PN Racing Aluminum ones to prevent it from happening again. Car runs great with them since they have Delrin shafts on the top and bottom suspension action is S M O O T H.
cvctiger is offline   Reply With Quote
Old 2006.03.05, 09:00 AM   #5
Spoon
DCGTG FET Guy
Spoon's Avatar
In engineering speak it's a longer moment arm.
Translating this toa real world example...
Imagine clamping a pencil to a desk and letting it hang about 6 inches off of the edge.
If you grab the pencil 1 inch away from the desk and try to break it, it's going to be difficult. If you grab it 6 inches away from the desk and try to break it, it's going to be pretty easy. You can generate more torque with the same amount of force because you have a longer lever.
Maybe it would have broken either way but I think making it too high certainly helped.
Old 2006.03.05, 09:06 AM   #6
did you order the 3racing or pn alloy knuckles?
Old 2006.03.05, 09:59 AM   #7
Spoon
DCGTG FET Guy
Spoon's Avatar
I actually just got the Kyosho plastic camber knuckles...1.5* and 3.0*
I don't know how I am going to like camber and the PN knuckles are something like $20 a pair. I figure I'll get the setup that i like and maybe get those PN knuckles to get rid of that stiction problem. (I think it's the PN ones with the delrin shafts)
WTB: Mini-Z AWD Stock Right Rear Knuckle aimfox Mini-Z Marketplace 13 2007.09.12 03:04 PM
MA-010 Stock Knuckle and tie rod ub0211042 Mini-Z AWD MA-010, MA-015 4 2007.03.23 01:23 PM
GPM .. they have many parts.. are they all available? bcuzau Mini-Z AWD MA-010, MA-015 5 2006.03.14 08:12 AM
Steering Knuckle broke already? Eternalight Parts and Hop-ups 6 2004.06.12 12:36 AM
GPM Knuckle arm problem ? *HELP* ATMOS Setups 6 2002.04.02 02:54 PM
