Old 2006.06.11, 08:44 PM   #1
Mazda787b
98mm Conversion kit??
I read about a 98mm conversion kit which allowed for wide offset wheels and bodies such as the McLaren F1. I can no longer find the thread, does anyone care to shed some light on thei subject?
There's no replacement for displacement.
Mazda787b is offline   Reply With Quote
Old 2006.06.11, 09:02 PM   #2
lfisminiz
lfisminiz's Avatar
Pn has it out now. Its adapters that make the chassis 98mm. It has longer spur gears with to match up. It also comes with the lay down crystal adapter to fit bodies better.
Old 2006.06.11, 09:40 PM   #3
Mazda787b
Just what I needed! I thought it was a Kyosho Item. Thanks alot!
Old 2006.06.12, 04:46 PM   #4
NismoRocks
NismoRocks's Avatar
Send a message via AIM to NismoRocks
i have a question about it
wouldnt the 98mm bodies be too wide for the awd?
NismoRocks is offline   Reply With Quote
Old 2006.06.12, 05:24 PM   #5
sciencemike
sciencemike's Avatar
98mm is the length of the wheelbase not the width. So no 98 mm is the perfect fit for a lot of the nice bodies like the Mclaren, Lambo Murci, Enzo, and best of all the Pan Car...
sciencemike is offline   Reply With Quote
Old 2006.06.12, 05:49 PM   #6
machine
learning the hard way
machine's Avatar
and with the low down crystal mounts it work with those bodies.
[Western Canada's Mini Rc Home[/URL]
machine is offline   Reply With Quote
Old 2006.06.12, 06:59 PM   #7
Mazda787b
What about super-wide offset wheels? I heard the wide rears aren't so good on the MA010.
Old 2006.06.12, 07:12 PM   #8
SaiTam
Are you Fetted?
SaiTam's Avatar
I used the extension kit and won the NY Regional event yesterday. The kit definitely helped stability and performance since I lapped everyone in the race easily. I also had a chance to drive PN's demo car and it too was awesome with the extension kit. The MA-010 should've come as a 98mm standard but the 90, 94mm confirguration helped Kyosho to sell more of those old/narrow bodies. My RTR weight with the kit was 7Oz.
Old 2006.06.12, 07:31 PM   #9
Mazda787b
Well, congratulations! Were the AWDs put in a seperate class, or with you with the 'traditional' racers?
Old 2006.06.12, 08:00 PM   #10
lfisminiz
lfisminiz's Avatar
Glad to hear you got your awd kickin!
Old 2006.06.12, 08:23 PM   #11
lfisminiz
lfisminiz's Avatar
SaiTam
What body did you run? How did your lap/time compare to the other classes.
Old 2006.06.12, 11:09 PM   #12
SaiTam
Are you Fetted?
SaiTam's Avatar
I used a modified Corvette body that accepts 98mm wheelbase. Best lap time was a hair faster than MR-02 stock. I ran with other MA-010 cars only, there were 90 and 94mm cars in the same race.
Old 2006.06.13, 08:32 PM   #13
lfisminiz
lfisminiz's Avatar
Thanks for info.
Old 2006.06.14, 10:38 PM   #14
NismoRocks
NismoRocks's Avatar
i was asking if there was a problem with width because the 98mm bodies are generally wider than 94 or 90mm and i was guessing you would need a wide offset
Old 2006.06.15, 03:29 PM   #15
Nightcargo
SaiTam,
Congrats on the win! Can you tell us any more on your setup? Motor, FET, Camber, Toe, do you use alloy parts? Thanks!
Nightcargo is offline   Reply With Quote
TGR Sinister Conversion Kit Z_408 Mini-Z Marketplace 2 2008.08.24 09:09 PM
Tempting new model kit screaming for conversion... sporadicidiocy Custom Bodies 2 2008.07.10 09:03 PM
PN Racing 98mm extension kit for AWD pchan0 Miscellaneous Discussion 1 2006.06.28 08:17 AM
Aluminium conposite chassis conversion kit from TaGu!! ikinari Parts and Hop-ups 22 2005.03.09 08:02 PM
Midship Conversion Kit Rick Parts and Hop-ups 6 2002.10.21 11:06 PM
