Old 2001.11.05, 06:16 PM   #1
zath
The Original-Member
help
ok i was in the proses of switching chases, i got the clear blue one, well every thing seamd to go fine (striped some screews) no when i turn it on to drive it just starts to smel funy, and it dosnt drive or stear or anything, and it gets raely hot. any info on whats wrong and what i can do about it.
zath is offline
Old 2001.11.05, 10:33 PM   #2
Russ
Super Moderator
Russ's Avatar
Re: Help
I know what's up, when you put the power wires back in, you got them reversed. I'm talking about the wires that get screwed in by the piece with the 2 prongs that hold the ESC board down...switch those. That happened to me the first time I rebuilt my Z. Make sure the positive (red) wire is on the spur gear side of the car, and the negative (black) wire is on the non-spur gear side of the car.
If that's not your problem, I'll be a monkey's uncle.
Russ
Russ is offline
Old 2001.11.05, 11:09 PM   #3
zath
The Original-Member
tried
tried it and it didnt work, though i did have them backwords, it stil dose the same thing?
zath is offline
Old 2001.11.05, 11:13 PM   #4
Russ
Super Moderator
Russ's Avatar
Re: tried
Ummm, well, u got me there...I hope you didn't burn anything up if you left it on too long with reversed polarity flowing through the board. A soon as I saw mine wasn't working right, I pretty much knew what was up, so I switched the wires and all was good, but if it's still doing the same thing, I don't know what else to tell ya, sorry dude, I did what I could If I think of something else, I'll tell you first thing.
Russ
Russ is offline
Old 2001.11.05, 11:44 PM   #5
zath
The Original-Member
good news
i hate to admit im wrong but i was, i went back and looked at the wires and they wear backwards so i switched them and bingo it workes great now.
thanks
zath is offline
US Atomic World Race Z_408 Atomic Mini-Z World Cup 108 2008.03.24 09:28 PM
throttle adjustment on the car? Zephyr von Bobo iWaver 9 2006.05.11 08:07 PM
Getting out of Mini-Z racing.... PD2 Miscellaneous Discussion 10 2006.01.19 09:35 PM
Car not moving forward or reverse newm5 Mini-Z Science 8 2005.12.16 01:40 AM
A new Stock Car class will be starting this fall at CP Mini RC Raceway Blackno3 CP Mini RC Raceway, NY 58 2004.10.27 09:23 PM
