Old 2006.07.13, 01:50 PM   #1
Spoon
DCGTG FET Guy
Spoon's Avatar
First Hopups
This question has been asked a thousand times, but the point of this thread is to try to make sure it's not answered ever again. Hopefully...
All new Mini-Z drivers like to know what their first hopups should be. Here are my thoughts, any additional input is welcome. Conflicting opinions openly welcomed.
Phase I - Bare Essentials (Best bang for buck, probably required to make a competitive racer)
  • Tires
  • Bearings
  • Carbon H-plate (MR01/MR02)
  • Damper System
Phase II - Good to have. Helps fine tune handling. Higher Performance.
  • Ball Diff
  • Toe In-Out Rods
  • Camber Knuckles
  • Springs
  • Upgraded motor
Phase III - Durability for Mod Racing and/or Bling
  • alloy motor mount(s)
  • Ti Damper Kits
  • Alloy Knuckles
  • Alloy or Ti Dogbones (MA-010)
For a little more discussion and a couple of links, you can reference the full article on the mini-zracing blog.
Enjoy
Spoon is offline
Old 2006.07.13, 05:53 PM   #2
soyverde
Hack Job Driver
soyverde's Avatar
Hmm, my phase I suggestions would only include tires and rechargeable (NiMH) batteries. Carbon H plates would be a distant third (possibly phase II), as depending on your preferences they may be more for reliability than performance (look at how well chucky does with stock plastic plates). They are typically one of my first upgrades, though. I would put bearings and (non-stock) damper systems in phase two, as I don't consider either particularly necessary to someone starting off.
I would also suggest that a decent digital controller might be useful before any of the stage III items, but then I don't care much for alloy, and that's pretty debatable.
soyverde is offline
Old 2006.07.13, 06:12 PM   #3
Spoon
DCGTG FET Guy
Spoon's Avatar
That's good input. I forgot about the rechargable batteries.
Spoon is offline
Old 2006.07.13, 07:50 PM   #4
FasterTHANu
Which Damper system should I use, the one that goes on top or the one that goes down either side? I've seen pics of cars that have both, is that over kill? Also what H plate should I use? Thanks
FasterTHANu is offline
Old 2006.07.13, 08:48 PM   #5
Spoon
DCGTG FET Guy
Spoon's Avatar
I would do a search or start a new thread asking about dampers. If you do start a new thread be sure to post which type of chassis it's on because the dampers are chassis specific. As SoyVerde mentioned though, a damper may be a later upgrade, definitely after tires and batteries.
Spoon is offline
Old 2006.07.15, 09:04 PM   #6
bermbuster
GF Racing
bermbuster's Avatar
your logic is spot on as far as upgrades...im new to mini z s but not RC cars/trucks. What is confusing is the wide range of hop ups and mfgs of them.(partial to kyosho) Now when i buy tires im getting 4 rears or 4 fronts per pack. The cool thing for me is that the 2 cars come with different tires(slicks &treads) and im getting an education from them. So now i need to make sure i get the right combo for the surface I want to run on. What tires work best on RCP track? My plans for now are bearings, tires, and maybe ball diffs. What spare parts do you reccomend we keep in our pit box??? Thanks again for all suggestions.
bermbuster is offline
Old 2006.07.16, 11:36 AM   #7
Fish
Fish's Avatar
Send a message via MSN to Fish
A lot of people also recommend replacing the stock lugs with nylon threaded ones right away. It'll decrease the chances that your wheels will come off during a race.
miniRC ca
Fish is offline
Old 2006.08.03, 02:36 AM   #8
Spoon
DCGTG FET Guy
Spoon's Avatar
just bumping this thread to try and get more input. I am going to clean it up and post the FAQ version soon so speak now or forever hold your peace.
Spoon is offline
Old 2006.08.03, 10:49 PM   #9
HammerZ
Master of Thrash
HammerZ's Avatar
  • Tires
  • Bearings
  • Damper System
  • Ball Diff
  • Toe In-Out Rods
  • Camber Knuckles
  • Springs
  • Upgraded motor
  • Ti Damper Kits
  • Alloy Knuckles
If anything I would bump the damper system to a phase II. I know some swear up and down on these, I just think you can get by without it for a bare bones car. Metal wheel nuts would fit there nice though, I like to upgrade those with the bearings. They also save headaches later when you are cleaning the car. When you have one car it would work to trick it out with everything, just when you have a few more cars those hopups add up quick. I figure I am doing good to have ball diffs on all my racer chassis.
HammerZ is offline
FS Mini Z F1 with hopups rc_speed Mini-Z Marketplace 1 2008.06.17 04:20 PM
FS: MR015, Radio & HopUps: Ready to Race Drew_Cat Mini-Z Marketplace 0 2008.04.03 12:29 PM
Hopups list.. help me out here Dirtbag Parts and Hop-ups 4 2002.11.05 02:53 PM
