Old 2006.08.29, 05:28 PM   #1
Phil Burr
New here, How fast??
Hello everone I'm a new guy here and was thinkin bout gettin one of these cars... Was just wondering how fast these things go? Stock vs Mod? I searched but have not really found anything. Any help would be great!! Thanx for tha COOL site.....
Phil
Phil Burr is offline   Reply With Quote
Old 2006.08.29, 06:40 PM   #2
bolter9
How're YOU doin?
bolter9's Avatar
Send a message via Yahoo to bolter9
depending on the pinion gear, you can probably expect a stock mini z to run somewhere around 15kph- standard x-speed motor upgrade will get you up to around 25kph.
If you mod your fets, you can run hotter motors...depending on the setup, you could easily generate enough speed to be unusable at this scale- I'm sure there's someone here who can provide more specific numbers on the options available.
For most indoor tracks, a standard x-speed is great for speed. These cars are all about handling...so it's best to get that dialed in first.
Hope that helps, and welcome to the forum
Havin' a good one!
My Gallery
bolter9 is offline   Reply With Quote
Old 2006.08.29, 08:04 PM   #3
builthatch
yes, it's a boxer
builthatch's Avatar
Phil
bolter has got it right- you can easily make these cars too fast, even tho their handling potential is sky high...
a simple 2x2 4562 stack (or 0113 fets like me ; ) and an atomic z2 will make for a car that is too fast for most tracks....it's that easy to go overboard.
with out of the box internals (non-modified board), you can run something like a Kyosho X-Speed, BB can, neo mags and some nice batteries like Intellect 750's and go pretty damn fast.
Reflex Racing :thumbup:
Old 2006.09.01, 04:34 AM   #4
NoX
Guest
Posts: n/a
just like bolter9 said, i think handling should be your concern when looking 4 a car...cuz too much speed and no handling = 0
Old 2006.09.01, 05:00 PM   #5
SuperFly
bitPimp
SuperFly's Avatar
Also, if you do a search for videos, you will find some good examples of typical speed on a track. Most of us race on RCP or similar track, and as said earlier, there is a limit to how fast you can/want to go and still turn good lap times.
mini-z gallery
Old 2006.09.01, 06:00 PM   #6
HammerZ
Master of Thrash
HammerZ's Avatar
This is a very typical question. I would answer it as stock out of the box the speed is good. With the right modifications the speed can be ballistic. I know it isn't saying much, as those of us that have run these things know just what these are capable of doing. As most posts here point to it is more about the handling than outright speed that is the big draw here. If you still have your heart set on speed, fets and a hot motor in an MR01 is about all it takes to zip down the street like it has a rocket attached to it.
I try to stay away from posting actual speed numbers as that usualy leads to oneupmanship. I say 18 MPH, then someone says "is that all, mine hits 25mph" then it goes from there.
Old 2006.09.01, 11:12 PM   #7
bolter9
How're YOU doin?
bolter9's Avatar
Agreed- I was just throwing out some ball park figures for general reference. You can expect to get in the range of "insert number" with this setup.
Havin' a good one!
My Gallery
Old 2006.09.06, 07:45 AM   #8
DogbreathRacing
MINI-Z MONSTER GARAGE
DogbreathRacing's Avatar
These cars are amazingly fast (or perhaps we should say that they LOOK very fast) for thier size and scale.
Lots of guys use speed checkers to measure the potential no-load speed but it is a whole different story when the car is on the track.
Even computer lap counters can not give you a direct overall speed.
The only way is to clock them with an actual radar gun, and when you do that you will be totally surprized at how low the actual speed is.
We have done some radar runs.....
Just as an example,
Stock PCB, 3R Neo BB motor 9T pinion, 1000Mah batts, 15 degree radials, ball diff, bearings, on an RCP track with a 16 ft straight (2 wide L sets together) and the best we could pull down the long straight was 12 mph....just an example
cars with FETs will do better as will cars on a larger track, we plan to radar some 45ft drag runs next week.
MR02RM, MR02MM, MZM,
Pro-Pulse Pro T-100 1/18 4X4,
Old 2006.10.03, 07:38 AM   #9
Phil Burr
Thanx for all the replies guys!! Handling is my priority just wanted to know if I would have to mod the crap outta a car straight out the box to keep up? 12 mph for a car this small is pretty stinkin fast. Now I just have to find someone close to me that races this scale. Not much racing going on in Arkansas.
Phil
Old 2006.10.03, 11:55 AM   #10
byebye
byebye's Avatar
Isn't Hammer or HammerZ in Arkansas?
I believe Spoon was doing a "google maps" thing so you could find racers in your area. Also I think Hammer or HammerZ LOL has a stickied RCP track thread for RCP owners to meet up and make a larger track.
-Byebye
Old 2006.10.03, 12:35 PM   #11
Spoon
DCGTG FET Guy
Spoon's Avatar
When you get a chance Phil, you shoudl drop your location on the map...Hopefully it will help us build the community.
http://www.frappr.com/?a=showmap2&mapid=2584898
autoscale bodies & their running characteristics herman Parts and Hop-ups 28 2004.11.30 12:19 PM
When is it fast enough? chelboed Mini-Z Overland MV-01 18 2003.08.10 07:48 PM
Hey Nomotor Limit. Do You Think My Car Is Fast??? mini Z modifier Parts and Hop-ups 191 2002.08.07 06:47 PM
Modified + Motor = How Fast? Machritis Parts and Hop-ups 0 2002.01.24 08:35 PM
How fast???? PorscheGuy964 Setups 1 2002.01.23 08:25 PM
