Old 2002.04.07, 01:19 PM   #1
SkylineR34man
╝Sexy man ^^^^
SkylineR34man's Avatar
Send a message via AIM to SkylineR34man
what does this do???????
I am going to buy some new alloy front nuckles, but they come only in 3 degre. What does the 3 degre nuckles do?? oh btw the alloy ones are a bit expensive so how are the nylon ones??? nay good?
thanks in advanced
Skyline
Waiting for my Overland...sigh*
SkylineR34man is offline
Old 2002.04.07, 05:46 PM   #2
mryung
Send a message via ICQ to mryung
For my opinion, I suggest you to buy the nylon one instead of alloy because nylon one is durable enough and light in weight.
Thomas
A Mini-Z player in Hong Kong.
mryung is offline
Old 2002.04.07, 06:43 PM   #3
Russ
Super Moderator
Russ's Avatar
the 3 degree means 3 degrees of camber, as in the tops of the wheels tilt inward 3 degrees. I replace my plastic parts with alloy as I break them and see the need for alloy in a certain place. I broke a set of nylon knuckles, and therefore upgraded to alloy 2 degree
If you are looking at the front of the car, the front tires will look like this:
It adds traction when turning, and creates more oversteer, but only if your tires are flat across and not rounded like the new, stock, kyosho tires.
Hope this helps!!
Russ
Russ is offline
Old 2002.04.07, 08:58 PM   #4
Wedginator
so Russ, which is the better camber angle? 3 deg or 2 deg?
Wedginator is offline
Old 2002.04.07, 10:19 PM   #5
Russ
Super Moderator
Russ's Avatar
hard to tell somtimes, but mostly depends on how much your car pushes in the turns, or how much understeer it has, and if you want to get rid if it.
I run 2 degree, if that says anything. But yeah, I just can't say which one is the best, because sometimes 1 deg. is the best, and sometimes 3 is the best, ya know??
Russ
Russ is offline
Old 2002.04.07, 10:49 PM   #6
SkylineR34man
╝Sexy man ^^^^
Thanks 4 taking ur time writing Russ it helped alot!!!!!!!!!!
Old 2002.04.08, 08:21 PM   #7
mini-z
Administrator
mini-z's Avatar
SkylineR34man, I would avoid the nylon ones, they are really fragile. Go with the alloys.
mini-z is offline
Old 2002.04.09, 02:59 AM   #8
PorscheGuy964
House Plant
PorscheGuy964's Avatar
Send a message via AIM to PorscheGuy964
R34man, yes you definatly should go with alloy steering knuckles. They won't break,although I'm sure someone with someday, and the travel alot smoother along the kingpin, even more so if its a stainless steel king pin. Plus nothing beats the look of ally parts on a mini-z....
My mini-z is an A.I.V.
PorscheGuy964 is offline
Old 2002.04.11, 12:44 AM   #9
yep... having more camber (the higher the degree's) will have you turn more aggresively into the turns. choosing the right camber would depend on how aggresive you would want to turn into the curves, and how technical the track is. normally the more turns the track has, the more camber you want.
to turn more aggresively into turns you can try this, take out the stabilizer bar in front, and place the springs over the steering knuckle where the steering pins are... aside from making your car turn more aggresively into the curves, this provides independent suspension (without costing a cent )... hope this helps.
herman is offline
Old 2002.04.11, 08:53 AM   #10
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
what camber?
Isn't real camber when you change the angle of the axis of steering? In this case it would be the angle of the king pin.
So, to increase camber you would need to angle the king pin back. (or back and in).
Ken Mifune is offline
Old 2002.04.11, 09:04 AM   #11
Russ
Super Moderator
Russ's Avatar
Ken, that's caster Camber is indeed tilting the tops of the wheels in, and caster is the rake of the kingpin. And toe is toe. Hehehe...
Russ
Russ is offline
Old 2002.04.11, 10:39 AM   #12
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
I thought caster is how far the axle is set back from the king pin.
what is camber and caster? herman Setups 1 2008.03.27 10:38 PM
Camber Question Jebroni Setups 5 2008.03.27 06:21 AM
CAMBER ADJUSTMENTS? anyone know of knuckles? PoorZDriver Setups 18 2005.01.08 11:38 PM
increase camber and toe-in with stock knuckles aznracer2003 Mini-Z Racer MR-02 9 2004.10.15 11:58 PM
Camber sets jcostantino Parts and Hop-ups 2 2002.01.02 01:43 PM
Copyright ę2011 Mini-ZRacer.com
