Old 2006.10.24, 01:09 AM   #1
gnehcoel
leo
GPM 8 degree tires for 11mm wide rims
hi GPM:
Are you going to make slightly wider 8 degree tires? Your tires are great to run on rcp, but it is not wide enough for the 11 mm wheel base.
thanks,
Leo
gnehcoel is offline   Reply With Quote
Old 2006.10.24, 03:13 PM   #2
Draconious
Draconious's Avatar
11m rims 11mm wheel base would be a very small car.. a micro machine
they work just fine on the wide rims... they dont need to overlap the rib on the rim... just but them up against the rib... the front tires are better narrow so the rim sticks out, this keeps the tire from comming off the rim when rubbing rcp rails...
Old 2006.10.25, 12:09 AM   #3
gnehcoel
leo
thanks draconious. sorry wrong term on the wheel base - it should be 11m rims ... haha
stock wide tires--what degree? Ng Luder Beginner Questions 15 2003.03.06 03:13 PM
GPM tires and wheels MrMojoRisin Parts and Hop-ups 3 2002.02.14 08:01 PM
GPM Foam Tires in shop...anyone have problems? MetaOrbit Parts and Hop-ups 7 2002.01.13 07:50 AM
GPM wide rears vs. Kyosho's wide rears Russ Parts and Hop-ups 5 2001.12.06 12:22 PM
Audi TT and GPM rims w/foam tires Kevin Parts and Hop-ups 2 2001.12.04 07:44 PM
