Old 2002.04.12, 07:13 AM   #1
Rextreme
Rextreme's Avatar
Chassis mount and new photos.
Hi Guys,
Finally getting around to posting improved pics of the FD's CRX and 911. they have been on my web site for a while though.
New improved custom mount.
Tupperware top plate with side pods and stick on velcro.
Velcro stuck to inside doors.
This time the tupperware was cut like a pod design I had previously. I just havn't added the extra holes for width adjust ment. I made the pod mounting holes in a position where all bodies fit I just padded the wider bodies a couple of milimeters with double sided tape this time.
I also didn't have to drill holes in the chassis like last time.
I just use the three top holes in the chassis. May change if you want to make one when using a damper.
It is much stronger this time around.
Russ.
RE-Xtreme! If your not driving at 45 degrees, Try harder!
Rextreme is offline   Reply With Quote
Old 2002.04.12, 07:15 AM   #2
Rextreme
Rextreme's Avatar
CRX
Altezza wheels look much better.
Old 2002.04.12, 07:17 AM   #3
Rextreme
Rextreme's Avatar
911/930
Width is still wierd though.
This body is now damaged. Front spoiler took a caning.
Old 2002.04.12, 07:19 AM   #4
Rextreme
Rextreme's Avatar
FD
FD!
Old 2002.04.12, 07:20 AM   #5
Rextreme
Rextreme's Avatar
FD
Under H bar.
Old 2002.04.12, 07:21 AM   #6
Rextreme
Rextreme's Avatar
FD New
Old 2002.04.12, 07:22 AM   #7
Rextreme
Rextreme's Avatar
FD New
More.
Old 2002.04.12, 05:34 PM   #8
DAMZer
Zen_gineer
DAMZer's Avatar
Very neat idea, especially for customs and LEXAN shells.
Is it raceable?
You're not really cutting up tupperware are you?
Old 2002.04.12, 05:51 PM   #9
Strider-
Strider-'s Avatar
Who makes that FD?
Strider- is offline   Reply With Quote
Old 2002.04.12, 06:22 PM   #10
Rextreme
Rextreme's Avatar
mount
Its pretty strong.
The Tupperware is strong yet fexible.
Strong enough for my H plate too but this gets a bit bouncy.
As far as the mount itself goes.
Should be good for race but I would add a front bumper of some description.
I screwed the porsche running into the gutter. OOps.
FDs are Fujimi. Tamiya FD's won't really work cause the front spoiler is on the chassis not the body.
Russ
ps. I think this one was actually DECOR not TUPPERWARE.
Old 2002.04.13, 06:01 PM   #11
mini-z
Administrator
mini-z's Avatar
Rextreme, great mounting system!
