Old 2006.11.21, 10:21 PM   #1
LBRC
LIT Mods
#1 Mini-Z LIT mod has to be a 9v PS jack for the charger. Cannibalized this one from a spare Epoch charger, when plugged in it opens the negative battery connection so you donít destroy the batteries with the power supply.
#2 is simply ball bearings, the LIT is hopeless without them.
#3 gets complicated but anybody who has ever tried to upgrade the motor in an Epoch then run it on a track should recognize the problem; battery current is in short supply and the steering goes to crap as the battery power gets low, especially in unfriendly radio reception environments. With the XSpeed upgrade motor it gets even worse. you almost need to be driving in perfect radio reception conditions to make 10 laps on a 2xWL RCP before your steering and throttle response gets squirrelly, even when using a peak charger.
From my trials trying to find a suitable Epoch upgrade motor solution I was expecting the problem, but had hopes that it was why they went with the KT-7 FM radio, but no. Problem is that the Mabuchi square can motors draw way too much current for small batteries, and with the added weight of the larger chassis combined with the higher voltage of the 4 cell pack itís quite noticeable.
As with the Epoch my fix works, the Shotgun motors are more receiver friendly while doubling the runtime even with the stock battery pack. But also as with the Epoch there is such a thing as too much speed, these things are top heavy and with any motor upgrade rolling becomes a major problem.
First Prototype
Second Prototype bottom
Second Prototype top view with Epoch tires
The lower Epoch tires help on the RCP track but you can't use them with the stock motor box.
Jungle Outlaw Micro Racing
LBRC is offline   Reply With Quote
Old 2006.11.22, 10:33 AM   #2
marc
Honda Insight Racer!
Sweet work. So is the Lit chassis the same physical size as the Epoch? Or is it slightly bigger? Can you take a side by side compairson picture?
Old 2006.11.24, 02:32 AM   #3
avant
Le ZŤdeur
avant's Avatar
@LBRC
ad 1. nice Mod - I've just soldered some "banana" connectors with cables on, so I can charge it with my ICE...
ad 2. ACK
ad 3. wow - great mod ! how does it handle compared the the standard powerpod ? I expect the Epoch diffi is not that smooth - right ?
I've solved the problem with the reception and the XSpeed motor just with another antenna - even if the antenna crosses the motor - works fine for me on our large 41m CRC track.
Cheers,
Jo
avant is offline   Reply With Quote
Old 2006.11.24, 01:43 PM   #4
LBRC
It uses the Mini-Z LIT differential and yes it is much smoother than the Epoch's, which is why I am also building a shorter one with a shortened LIT Differential for an Epoch.
Handling is a definite improvement although it looks funny hanging off the back since it's only 11mm thick, about half the height of the stock LIT motor box. It is also lighter than the stock LIT motor and box while being quite a bit faster than the LIT XSpeed motor.
Old 2006.11.24, 10:43 PM   #5
LBRC
The LIT is slightly bigger.
WTZ: AutoScales, MR01's, and Lit marc Mini-Z Marketplace 78 2008.10.25 04:32 PM
SOLD: The mother of them all, Mini-Z AWD package DeOz Mini-Z Marketplace 14 2007.10.30 05:55 PM
Upgrading the Lit marc Mini-Z Lit ML-010 14 2007.05.20 05:18 PM
How much fun is the Lit? marc Mini-Z Lit ML-010 31 2007.03.04 05:08 PM
Mini-Z Lit bodies and option parts marc Kyosho 0 2007.01.26 09:26 PM
