Old 2007.02.04, 08:50 PM   #1
JoeKimble
Something extra on my Xspeed
Anyone know what this is attached to the neg wire on this Xspeed motor? I have 2 and it is only on one of them.
I also have 2 MR-02 RM and one stock motor has it and the other doesnt...
Any Ideas??
Xspeed!
JoeKimble is offline   Reply With Quote
Old 2007.02.04, 08:55 PM   #2
Spoon
DCGTG FET Guy
Spoon's Avatar
I am pretty sure it's a capacitor. Not sure if it's for power or to suppress interference/glitching. I have seen people do that before, not sure exactly what the deal is.
Old 2007.02.04, 09:10 PM   #3
JoeKimble
Well I removed it from my stock motor and it seems to not made much of a difference. Anyone else have any clue as to what it is supposed to do?
Old 2007.02.04, 09:30 PM   #4
locwan
locwan's Avatar
It's not a capacitor. It's a circuit breaker that is also being fitted to the newer AWD chassis sets. It's really like a fuse, and works when the current draw from the motor is too high and "trips" it so to speak, cutting power to the motor and saving you a burnt pcb/fets.
However, I usually see it attached to the positive lead that's connected to the eye terminal attached to the pcb. I'm not sure if it works the same way when attached to different points of the motor/pcb.
See a previous discussion on it here: http://www.minizracer.com/forums/sho...407#post239407
locwan is offline   Reply With Quote
Old 2007.02.05, 09:51 AM   #5
JoeKimble
Do you think this could be effecting performance at all? My MR-02 seems a little caster with it off the motor. Should I leave it on the xspeed? Like I said I bought 2 of them and 1 had the circuit breaker and the other didnt.
Old 2007.02.05, 11:11 AM   #6
locwan
locwan's Avatar
I didn't see much performance drops when I kept it on my AWD xspeed motor. Frankly speaking, the breaker is not necessary when fitted to an Xspeed, which is well below the thrushold of what a stock pcb can handle. However, it would be help save you a burnt pcb/fets in the event of a sudden increase in drive-line friction, or the car hitting a barrier w/ the throttle kept on, which can cause the fets to overheat.
My suggestion is if it doesn't bother you in terms of performance, then leave it on there for safety. Better safe than sorry.
Gen-1 Xspeed vs AWD Xspeed helee4 Mini-Z AWD MA-010, MA-015 6 2008.02.13 07:37 AM
Old XSpeed and new AWD XSpeed HighFreq Mini-Z AWD MA-010, MA-015 6 2006.11.22 12:25 PM
Slow Xspeed jude26 Mini-Z Racer MR-02 7 2004.02.10 11:12 AM
Extra batt. 4 Xtra-Fast helldriver Mini-Z Science 3 2003.02.19 10:13 PM
