Old 2007.04.26, 08:34 AM   #1
Ton
Ton's Avatar
Atomic AAA Battery Discharger (Ver. II).
Ton is offline   Reply With Quote
Old 2007.04.26, 09:42 AM   #2
Spoon
DCGTG FET Guy
Spoon's Avatar
Yeah, those clips are going to be way better than the screw terminals...
Old 2007.05.15, 01:49 PM   #3
Spoon
DCGTG FET Guy
Spoon's Avatar
So, is this available yet or still coming?
Old 2012.04.14, 09:57 AM   #4
NoBrainer
NoBrainer's Avatar
Is there a manual or a place I can look to see what the LED's mean?
Tried Atomics site but could not locate any manual.
I just don't understand those LED's, since the same LED's light up no matter which order I put in the AAA's.
Even if I swap AAA's around it still says the same.
I thought first it was 1 LED pr AAA. But that don't make any sence to meafter I tested it a while.
Using mostly R1 Wurks 990mAh AAA.
Old 2012.04.14, 09:59 PM   #5
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
Basically they light up on whats left in the batteries. when the lights go out they are discharge.
Awesome RC Racing R.I.P
Old 2012.04.14, 11:10 PM   #6
unearthed name
And Atomic are wired parallelly so you need to have all 4 batteries connected at the same time in order for them to discharge.
Old 2012.04.15, 05:15 AM   #7
NoBrainer
NoBrainer's Avatar
Didn't know about that parallell thing, but ok.
If I understand you guys correct, I can't use this discharger to see whichone of my four cells that is bad. Since the LED's don't represent the actuall cells.
Old 2012.04.15, 08:35 AM   #8
unearthed name
Well it's just indicating which battery are charged and which one is empty. Maybe you should try to tighten the screw to the terminal. They sometimes got loose.
Old 2012.04.15, 03:57 PM   #9
NoBrainer
NoBrainer's Avatar
ok, thanks.
I found out that the terminals needed to get thighten.
Now I just have to test your theory tomorrow.
Old 2012.04.16, 12:25 AM   #10
ub0211042
ub0211042's Avatar
Anyone knows where to get the clip type contacts, wanna upgrade my screw type discharger
Mini-Z AWD 2.4Ghz 94mm
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
FX-101 Dnano 360 Modena
Old 2012.04.16, 06:57 AM   #11
NoBrainer
NoBrainer's Avatar
I don't know. I just bought this one with the clips.
But...thanks to unearthed name I fixed 2 terminals.
Now I get this.
From this I think I can conclude that at least the LED is defect??
Or might there be other issues?
I might swap a LED just to see. Are they ordenary LED's, so that I just can replace them?
The soldering looks good on the one side I can see. I don't know if there are other components on the other side, since I did not want to mess with it right now.
Old 2012.04.23, 07:20 AM   #12
NoBrainer
NoBrainer's Avatar
Picked it apart today.
The LED's that not lit seems to be defect.
It's 3mm LED's.
The only LED's I got that is 3mm is a Bright White 3.2V 20mA. Do some of you know if that's going to work?
EDIT: Tested now, it works. It's the LED that defect. Would have been nice to get confirmed what type of LED this unit is using.
EDIT2: Finished
Works like charm....
Old 2012.04.23, 12:32 PM   #13
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
It's 3mm LED's.
EDIT2: Finished
Nice job. Where did you get those LED's?
Old 2012.04.23, 02:46 PM   #14
NoBrainer
NoBrainer's Avatar
they are bought at a local electronic store, so I can't help you with that.
Old 2012.04.24, 10:08 PM   #15
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
Well I never thought of fixing my discharge trays till I read this post and seen how nobrainer fixed the problem. Went to RadioShack and bought a couple packs of low intensity 3mm red LEDs for a few bucks. They look identical to the original LEDs. And so far it works. Thanks for the post nobrainer.
Atomic Discharger question sefe Batteries, Chargers and Dischargers 1 2007.11.05 04:40 AM
Atomic AAA Battery Charging Rack II. Ton Atomic 1 2007.05.25 08:56 AM
FS: RTR awd, RTR F1 Faze Mini-Z Marketplace 14 2007.05.22 03:37 AM
Atomic News... Crystals and Discharger AAA... GGTuning.com Batteries, Chargers and Dischargers 7 2006.12.03 10:04 PM
AAA Battery Discharger Shaun Mini-Z Science 1 2002.03.18 06:18 PM
