Old 2007.06.26, 09:48 PM   #1
JamesJozef
44T Motor
I've read that 43 turns is the max for 3010 FET's, and 44 is one over that, so it's safe, but how long could expect to run it for without melting/warping the stock kyosho motor mount?
Soon to be MR-02 owner.
JamesJozef is offline   Reply With Quote
Old 2007.06.27, 12:00 AM   #2
hakhawk
44 should be fine. its only if you go less turns im pretty sure. going say a 25 turn motor is going to draw more current than a 50turn motor.
hakhawk is offline   Reply With Quote
Old 2007.06.27, 02:28 AM   #3
Flashsp-2
motor guru
Flashsp-2's Avatar
44 turns is perfectly fine for the FETs, I have run as low as 35 without any damage. I would say to keep an eye on the chassis directly above the motor, I melted that before I did the stock motor holder. The motor holder has a steady supply of air, but above the motor is nothing but heat and tight space. I don't know how long you plan on running it, but I would check on it after every pack.
Old 2007.06.27, 08:49 AM   #4
JamesJozef
You're correct. I'm just making sure for when and if my order from tinyrc comes in.
Mini Speedway Kyosho Stock Motor Cleaning Test schmenzer Motor Tech 3 2008.02.25 12:20 AM
Best all around Stock Motor to use without Fet upgrade Warchild Motor Tech 37 2005.11.07 08:33 AM
Tips and Tricks on the NML SSV.3 NOMOTORLIMIT Motor Tech 1 2005.02.20 03:49 PM
Review of NML non Turbo motor!!! MazdaSpeedRX-7 Motor Tech 12 2003.02.27 12:27 PM
The Truth On How To Make Your Very Own Armature For Your Your Mini-z Motor!!!! manchowder4u Miscellaneous Discussion 7 2002.08.22 03:14 PM
