Old 2007.07.13, 03:11 AM   #1
Z_408
Increase motor braking w/Helio EX-10?
I was wondering if anyone knows if it is possible to increase the amount of motor brake during coasting. I have the brake turned all the way up and when I let go of the throttle, it coast for a long time. I would like for the car (MR-02) to decrease in speed when I let off. I know I can put a different motor or magnets that will give me this effect, but I would like to know if it is possible to do with just the TX.
Thanks in advance for you help,
Z_408
Z_408 is offline   Reply With Quote
Old 2007.07.13, 09:14 AM   #2
could you not adjust an end point adjustment? god knows there are enough things to adjust with the ex-10, i am almost certain that what you want can be done in some fashion. then again, i have to ask spoon how to fix my helios
Old 2007.07.13, 01:08 PM   #3
pchan0
Team ShoBoi
pchan0's Avatar
Send a message via ICQ to pchan0 Send a message via MSN to pchan0
Z_408
Drag brake you mean? Go negative/reverse on throttle trim.
pchan0 is offline   Reply With Quote
Old 2007.07.13, 01:38 PM   #4
Z_408
I have tried negative throttle trim. When I do this I can not engage reverse.
Old 2007.07.13, 07:53 PM   #5
jbevins
Send a message via AIM to jbevins Send a message via Yahoo to jbevins
if your using the stock controller then when you adjust the throttle to negative/reverse like everyone is saying then the brakes should kick in as soon as you let off the throttle, now if you have the trim maxxed then as soon as your car stops, it may kick into reverse
jbevins is offline   Reply With Quote
Old 2007.07.16, 12:44 AM   #6
benmlee
You can't engage reverse because when you let go of the throttle, the car is already in reverse. You need to press the throttle a little to get back to neutral and then go into reverse. Sometimes is very tough to find neutral. You end up trying several times to go into reverse.
You are in luck if you have a EX-10. Assign throttle preset to one of the button. Set the throttle preset to jump to neutral whenever you press the preset button. Now all you have to do is press the preset button to go into reverse.
Also if you want more braking than throttle trim let you have, you can also set the subtrim to reverse.
Old 2007.07.19, 03:58 PM   #7
Z_408
Thanks for the information. I will give this a try.
Old 2007.09.18, 01:55 PM   #8
DeOz
Yo buddy whats up? Besides your standard trim (sounds like you have already adjusted) where do you have your "Sub" trim set for? Also what % do you have for rev on the remote?
I will be at ILR Wed. I should be able to get that to work for ya.
- Dana
DeOz is offline   Reply With Quote
Sudden increase in throttle power okashii_kuso Mini-Z AWD MA-010, MA-015 4 2008.09.08 11:47 PM
increase direction .:GuG05:. Mini-Z Overland MV-01 1 2006.02.09 05:00 AM
increase camber and toe-in with stock knuckles aznracer2003 Mini-Z Racer MR-02 9 2004.10.16 12:58 AM
How can i increase the wheelbase capsalt Mini-Z Overland MV-01 8 2004.04.08 03:54 PM
how to increase the power of mr-02 transmitter? spirit Mini-Z Science 9 2003.09.03 08:44 AM
