Old 2007.10.26, 10:36 AM   #1
Mini-Me-Zee
Originally Posted by CoreAnalog
Hi Guys,
I wouldn't touch the loop on the current core systems.
Sorry, for the long absence from the forums. We've been extremely busy with our engineering projects. We will be releasing a new system that can be used for larger scale cars. It's being used in private testing now and will have to be put through FCC/CE certification once the tesing period is over. We'll have it ready for purchase early next year. The system and transponders will be much cheaper (approx 50% price reduction from retail prices).
Current core stuff is also 50% off on the website.
Regards,
--Core
Hi Core,
Glad to see you are back. I have some questions I was hoping you might answer:
1. Is the new system for larger scale cars compatible with smaller cars? In other words, are the transponders a different size, or is it just that the "loop" (or whatever you may use) will span a larger area for wider tracks.
2. Will Core be more readily available for support after release of the new system?
3. Will the current transponders and software work with the new system? Meaning, for those of us that have the current Core hardware and software, could we just buy the new larger loop and its associated hardware separately from the new software and new transponders?
Thank you.
Mini-Me-Zee is offline   Reply With Quote
Old 2007.10.26, 12:53 PM   #2
i split this question out as it had nothing to do with the original question
Old 2007.10.27, 10:41 AM   #3
Mini-Me-Zee
Okeedoke, Arch2b, thanks!
Old 2007.10.28, 05:13 PM   #4
CoreAnalog
Originally Posted by Mini-Me-Zee
Hi Core,
Thank you.
1. We are making a user tweakable version where you can change the antenna length to suit the transponder and car size.
2. Yes, we've always been available for support. Our email is support at corespeedway.com.
3. Things should be much lower cost so this shouldn't be an issue.
--Core
CoreAnalog is offline   Reply With Quote
Old 2007.11.11, 05:56 PM   #5
gasman1
gasman1's Avatar
Send a message via AIM to gasman1
Has Core been tested with Vista and have there been any issues? My data folder doesn't update during and after race setup. My folders are not hidden, I re-installed Core several times with no luck. Any help would be appreciated
http://www.dorksonwheels com
gasman1 is offline   Reply With Quote
Core Analog Recently Asked Questions arch2b Core Analog 1 2008.03.18 01:36 PM
Core Installation Options and Startup Problems Jonny Core Lap Timing System Support Forum 8 2008.03.04 09:45 PM
Kyosho to exclusively distribute the Core System! CoreAnalog Core Lap Timing System Support Forum 50 2006.09.07 11:53 AM
Attn: CORE ->linking multiple core systems together? Sinister_Y Core Lap Timing System Support Forum 5 2006.08.06 12:40 AM
Adding Audio Files to Core Timing Software briankstan Core Lap Timing System Support Forum 1 2006.07.05 12:05 PM
