Old 2007.11.08, 10:49 AM   #1
F1Jet
X-mod radio swap
Does anybody know of a different radio system that can be used with a Radio Shack X-Mod? What is the difference in the X-mod receiver compared to a Mini-Z?
thanks
F1Jet is offline   Reply With Quote
Old 2007.11.08, 07:22 PM   #2
minizforever
minizforever's Avatar
Send a message via AIM to minizforever
I can't say what the difference is between the Xmods and the Mini-Z reciever's but I know for sure that the Xmods will only work with that controller that it comes with.
MR02 with some mods on it...
Also, I am in the state of north carolina.
--Signature your in it put ,this read to time the took you if.--
minizforever is offline   Reply With Quote
Old 2007.11.08, 11:36 PM   #3
fixed13
I secound that mods will only work with the radio they came with cause I have tried some different 27mhz radios with mine. I have seen some tuts on how to convert mods to other boards, I think one may have been here and one may have been on atomic mods website.
fixed13 is offline   Reply With Quote
Old 2007.11.09, 08:18 AM   #4
F1Jet
Okay, thanks for the info. I really like the car (heavy with independent suspension all four wheels) but the radio is so toyish I'd really like to change it. Does anybody know what kind of signal the transmitter generates? Is it analog wave or a PCM or some other signal?
Old 2007.11.09, 10:38 AM   #5
cowboysir
There is a certain part of the RX signal that makes the Rx/Tx system unique...the only way to change radios is to change EP's.
If you're keen on four wheel independant suspension, check out the MA010 with the SAS rear system:
better steering
better throttle control
stronger plastic platform
my custom body album...
FS: Highly modified KT-18 radio color01 Mini-Z Marketplace 0 2008.09.11 01:45 PM
sanwa module to KO radio QDriver Mini-Z AWD MA-010, MA-015 0 2007.12.26 04:24 AM
sanwa TX module to KO radio QDriver Mini-Z Science 0 2007.12.24 01:41 AM
About the iWaver Radio ... 1ofdfew323 iWaver 15 2006.07.09 06:34 PM
FS: Ko Propo Mars R radio for Mini-Z - $150 pchan0 Miscellaneous Discussion 0 2003.08.25 04:52 PM
