Old 2007.11.10, 12:59 PM   #1
Rooster
Need help with Steering assembly
Hi Guys..
Can someone pls post a pic or two of the steering assembly with the new "servosaver"..
I have got it to work but not to my satisfaction..
Peter
Rooster is offline   Reply With Quote
Old 2007.11.11, 12:29 AM   #2
rclifeform
Hope this helps
Hi, I had to do some modifications to my car when I received it. The steering linkage has a red eyelet in the middle which I sanded/grinded in order to shorten it. You may have to do the same if it is the same problem I had.
rclifeform is offline   Reply With Quote
Old 2007.11.11, 04:32 AM   #3
Rooster
Ok Thanks for the pics..
Yes thats the way i did it aswell, but the steering radius is restricted by this kind of assembly, and its a must to reduce the EPAs on the radio otherwise you will destoy the servo.
Seems to me like a late afternoon solution...
Peter
Old 2007.11.11, 11:45 AM   #4
rclifeform
Steering help
Hi, I replaced the the tgr kingpins with the PN racing kingpins because the PN kingpins are a little longer and cleaner. I used the Kyosho e-clips to hold the PN racing kingpins and I also placed on the kingpins against the front springs to take up some of the play because of the longer kingpins. I also placed some washers underneath the red front brace holders in order to get more clearance for the servo horn. I don't have any trouble with getting full steering after this mod. Hope this helps.
Old 2007.11.12, 05:14 PM   #5
Rooster
Yes but the problem as I see it (only on the workbench so far, might not even be a problem) is that the servo arm is rotating in a circular movement and the steering rod in horisontal, there is bound to be stress on the servo in an early stage. My thoughts are to try to make a steering rod similar to the ones on the Iwaver 02M, where you have a (long) hole that allows the servoarm to move (up and down).
But then again these are so far workbench related questions, perhaps it runs and turns without any problems when it comes out on the track.
Peter
Old 2007.11.13, 02:29 AM   #6
Wolf
Wolf's Avatar
Peter
Dear Peter,
Your comments are right on theoretical platform. As you also said it is not a problem on the track. Since there is a pivot point between servo horn and short eyelet and also knuckles permit steering rod to move up and down, it does not create a stress on the servo. On the other hand the other alternative may create larger gap where as we want our car's steering as stiff as possible to obey our commands.
Regards
Sinister
Old 2007.12.10, 03:40 PM   #7
Rooster
I think more people than me have experienced the "locking" of the front suspension when steering, this is the same solution I have allready planned..
http://rctech.net/forum/attachment.p...0&d=1197270340
http://rctech.net/forum/attachment.p...9&d=1197270318
Peter
Old 2007.12.15, 10:58 AM   #8
marc
Honda Insight Racer!
I don't know anything about the TGR, but you mentioned Iwaver, couldn't you use the tie-rod arm from the 02M chassis? Seems like it will do what you want or is it not the right size and/or shape?
Old 2007.12.17, 05:18 PM   #9
Rooster
No i think i am going to grind of (or make new ones) the servoholderblocks and thereby move the servo backwards, to make a little more space for the new assembly, similar to the one I have on my PRO 27.
Peter
Old 2008.02.19, 01:47 AM   #10
tudor_47
tudor_47's Avatar
the quest for steering goes on,
I was thinking that i would be possible to make a new brace for the top of the steering that is not a straight piece of carbon but instead swept forward in the middle to give room for the servo-arm in that way a few more mm would be freed up for the servo movement. I have managed to get my steering working, well for a short period atleast, the nut for the servosaver spring comes loose.
In the middle were the piece is swept forward holes needs to be done for the body-posts. maybe new body posts are needed?
/Johnny
Get a P28
Old 2008.02.19, 01:55 AM   #11
rclifeform
Hi, replace those nuts on the servo saver linkage with wheel nuts which are locknuts. I lowered my servo by trimming the mounting tabs on the servo as described on the TGR sinister website. I also removed the round silver spacers under the knuckles and I have good suspension travel and good steering.
Old 2008.02.19, 02:02 AM   #12
tudor_47
tudor_47's Avatar
Wow! Rclifeform!!
you said something there, remove the silver spacers..that would make the knuckles drop down and free up the suspension!!! great!
did you put the spacer ontop of the springs instead? perhaps it is better to put it ontop of the knuckle?
I need to get in there with a washer as the spring is not under tension as it is too short...
I'll report back on progress......
!!EDIT!!!
this would however make the car sit higher infront.. Is this an issue?
!!END EDIT!!
Thanks!!
/Johnny
/Johnny
Get a P28
Old 2008.02.19, 02:11 AM   #13
rclifeform
Hi, i'm using pn springs with the pn red limiters and yes I have the springs on top of the pn knuckles. I took a black piston from my 1/10scale rc shocks and used it as a spacer so there would be more tension on the springs. You can use the black piston(spacer) to adjust the front ride height by either placing below the knuckle or above the knuckle. Get yourself some pn mr-02 front springs. Good luck.
Old 2008.02.19, 02:35 AM   #14
tudor_47
tudor_47's Avatar
Hi
thanks!
I will examine my other Mini_z springs... I am afraid the PN-parts are difficult to get to here in europe.. It is usually needed to order them from the US and it tends to get very expensive.
I do have some Atomic springs and perhaps even som e Kyosho springs.
/Johnny
Get a P28
Old 2008.04.04, 09:29 AM   #15
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
this is the way ive got mine
mini-z f1 kingpins sunk into chassis,mr02 limiters and springs.
the important thing with the steering is to make sure the servo saver part is at the right angle,the centre servo part has no threads inside so the bar can move back and forth aswell as side to side
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
is there any difference with the Kyosho MINI Z MR02 alloy steering assembly erixxst Parts and Hop-ups 0 2008.09.10 11:32 AM
Help. Steering won't center. Phenochilus Mini-Z Racer MR-02 8 2007.07.10 09:51 PM
MM02 steering problem pyro147 Beginner Questions 6 2006.03.29 02:54 AM
iWaver02 steering twitch / steering steps FIX!!! trueno92 iWaver 0 2005.04.23 12:09 AM
gpm steering parts problem marlboro Mini-Z Overland MV-01 1 2004.06.29 07:27 PM
