Go Back   Mini-ZRacer.com Forums > Manufacturers > TGR
Old 2008.01.20, 04:45 AM   #1
Wolf
Wolf's Avatar
Belt Drive Differential System (BDDS) from TGR
Innovation Spirit
At TGR we always search, think, brainstorm on what we can do to evolve this scene.
Now it comes; The ultimate transmission differential with infinite gear ratio.
Its totally a unique design by TGR. It is belt driven, it is steel, it is small and fluent in action. We've tested this system for several months in our factory test track away from the crowd. For the last several weekends we've started to use it with people who comes to our track. Everybody noticed how quiet does our car go. First they thought about a perfect mesh. But when our car was alone in the track and people started to hear even the servo sound from the car at the end of the straight; secret was over! We've opened the hood and the same question arised
WHY??
BECAUSE MOTORS NEEDS THIS
Most highend racers are aware that 130 sized motors' timing are reverse reatarted. This is due to mass production of motorcans and hobby usage is really low. Many people observes that their cars go faster and with more punch when it goes reverse. Another symptom of this problem is the AWD's which performs almost the same speeds with 2WDs despite the gear ratio. Since motors used with reversed polarity in AWDs those timing error auto corrects it self.
However we couldn't add more gears to 2WD to correct spinning direction. Solution is simple. Using a belt instead of gears results in a correct direction spin for the motor, regarding its timing.
BECAUSE RACERS NEED MORE & MORE GEAR RATIOS THAN THEY HAVE
Since it has no teeths but has wheels, all you have to do is to adjust your pinion or spur radius. Just you name it. You need a pinion with 3mm radius or 2,5. Ah you need a little more punch? Then how about 2.225 or would you prefer 2.1234? You can even create your very own and secret pinion for your motors' or track's need.
BECAUSE WE DON'T WANT TO CARRY THE WEIGHT OF PRESSURE PLATES IN OUR DIFFS
All differentials on the market has D cut or even worse O cut pressure plates to transfer the action. We thought if we use hardened steel as the caps and we can get rid of large heavy pressureplates. It is even harder than the common pressure plates which are infact used as washers in the industry. Moreover it is lighter than conventional cap+pressure plate combination.
BECAUSE wE WANTED TO HAVE AN OUTER TUNED DIFF BUT IT SHOULD BE REALLY TUNED!!
Most racers like the idea of tuning of the diffs from the outer nut. However many diffs on the market has problems when you need a realy tight differential. Due to ball size versus ballbearing cage thickness issue, you can not over tighten most differentials. Solution to this was also simple. With the cost of extra machining we've moved the ball bearing just a little into pressure cap. Here it goes. A differential which is really adjusted and adjustment is from the outer nut.
All those reasons led us to this unique innovative design.
Now lets take a look at other features of TGR Belt Driven Differential System (BDDS)
Steel shaft, caps, wheel adapter.
Hear treated extra hardened pressure caps
Extra Lightened 8 Ball Spur
Sinister
Old 2008.01.20, 05:25 AM   #2
Flashsp-2
motor guru
Flashsp-2's Avatar
Wolf, that is simply amazing. Hopefully those motors will arrive before you guys head to the toy fair. I imagine that thing is going to make quite the showing with that new belt drive system...
Old 2008.01.20, 07:42 AM   #3
xoxide
Hazardous Designs
Yes this is smart! I want one! So will they fit with just a normal MR-02 ir do you have to have a TGR?
xoxide is offline   Reply With Quote
Old 2008.01.20, 08:01 AM   #4
Wolf
Wolf's Avatar
It fits to MR02 also
Sinister
Old 2008.01.20, 08:48 AM   #5
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
the wonders never cease
i need to get my hands on one!!!!
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2008.01.20, 09:31 AM   #6
i'd really like to see one of these in action myself.
Old 2008.01.20, 09:51 AM   #7
Jonny
Fantastic work to the TGR crew. I'm really looking forward to this!
Jonny
Old 2008.01.20, 10:26 AM   #8
wcrotty
Send a message via AIM to wcrotty
Don't you have to run the motor in reverse?
most motors are designed to go one way......the timing only works one way. So if you run it in reverse the timing is wrong.
It looks like you have no diff action at all. So this is a straight axle?
PN Team Driver
2008 PN World Champion
2008 PN Canadian Champion
2006 PN World Champion
2004 Kyosho Cup National Champion
2003 Kyosho Cup National Champion
wcrotty is offline   Reply With Quote
Old 2008.01.20, 01:36 PM   #9
mk2kompressor
the diff rings are built in to the outdrives,8 balls,and the thrust bearings are sunk in
the timing works both ways,90% of factory built motors ive looked at are approx 5deg retarded
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.01.20, 11:34 PM   #10
Wolf
Wolf's Avatar
Thanks for all comments, questions and feedbacks.
Main question is do we have to run the motor in reverse?
Yes. As Matt already pointed 90% (infact I haven't seen opposite yet) of the motors on the market have retarted timing. Where as we prefer to have advanced timing for modified races. I guess this is due to mass production of the cans and regular uses of 130 size motors in the industry. And since hobby usage is relatively too small we are faced with this situation. What we are stating here is, motors with retarted timing will perform better if you use them in reverse. And we've given simple indicators of it in our introduction message.
Another question is about diff action. Spur, pressure plates and shaft pictures are above. Pressure plates are also diff cap or outdrive in this design. They are heat treated to get get extreme toughness. Moreover pressureplate which is close to the motor locks to shaft with extreme tight fit. Whereas the outer one with wheel adapter has free spin over shaft. Just like any regular diff. However this design is too compact that, I can understand assembled photos looks like it is a solid axle. But it is definately not.
We'll have some more new and innovative products which will be announced ver soon.
Sinister
Old 2008.01.21, 12:15 AM   #11
Programmers
iTomCash
That's a fantastic idea and I'd love to get my hands on one. However, I naturally assume that there would be quite a few flaws such as...
What about the belt coming off the motor pinion?
What about snappage?
What about slipping in more powerful motors?
Unless you've already dealt with them.
Old 2008.01.21, 12:55 AM   #12
I assume those issues can be dealt with by upping the belt tension. But then I am worried about belt tension changing nearly every run if this system uses tension and not teeth to transfer power.
I think it's a great idea, but I would really, really like to see a toothed belt. IMO it would do wonders for reliability and probably improve the rolling resistance as well since you don't need to use any belt tension at all -- let the teeth do the work.
Old 2008.01.21, 05:13 AM   #13
Wolf
Wolf's Avatar
@programmers;
Due to my poor english; either your first and second questions are the same or the second and third. Can you explain the snappage?
By the way, we've already tried many motors including chili, anima etc without any problem.
@color;
As you know even toothed belts has a part called "belt tensioner". Moreover when teets involved you ar again limited to certain amount of teeth count; as a result limited gear ratio alternative. Especially thinking about the small area we have, we'll defintely have many small amount of pinions and spurs if we use toothed belts.
Sinister
Old 2008.01.21, 08:01 AM   #14
Programmers
iTomCash
I was wondering about if the belt comes off?? Like if you hit something for example?
Old 2008.01.21, 08:40 AM   #15
Davey G
Need a mini z Painted????
Davey G's Avatar
Hi Wolf,
Its nice to see your company coming up with cool ideas for these little cars. I have 2 questions though. Have you tested the amp draw (efficiency) of your belt drive verse gear drive? I would have to assume that the belt will less efficient, meaning it will draw more amperage due to having constant pressure against the belt. My other question isnt direct towards you directly WOLF, but really to the MINI Z industry. If what your saying is fact that the motors timing is retarded, why hasnt anyone stepped up and made a motor pod that mounts the motor on the opposite side of the car???
Dave Graboski
DG Designs
TGR Sinister Chassis and TGR Sinister Pro Chassis Kel Parts and Hop-ups 36 2007.10.11 02:28 AM
