Go Back   Mini-ZRacer.com Forums > Manufacturers > TGR
Old 2008.01.21, 09:10 AM   #16
wcrotty
Send a message via AIM to wcrotty
I have tried a few 2wd belt driven cars in my day and never have
they been more efficient or faster. If it was then you would see
all 10th and 12th scale direct drive cars with belt driven systems.
the pressure needed to keep the belt from slipping took power away
from the motor. For the Rc10 i tried the trackmaster belt transmission and the
hyperdrive belt system. Also a direct drive 2wd car. I can't remember the name.
Now that all said. Maybe the mini-z cars are light enough not to worry about slip and power loss but I'm not sure about that.
Dave G, PN does have a motor pod out on the other side but that is for the nascar mini-z and to run oval.
PN Team Driver
2008 PN World Champion
2008 PN Canadian Champion
2006 PN World Champion
2004 Kyosho Cup National Champion
2003 Kyosho Cup National Champion
wcrotty is offline   Reply With Quote
Old 2008.01.21, 09:38 AM   #17
pinoyboy
pinoyboy's Avatar
wcrotty beat me to it, but PN makes a mount that looks like it can be run in 102mm and 98mm
Old 2008.01.21, 01:03 PM   #18
ruf
4play
ruf's Avatar
Not only that, this is not a toothed belt, but a friction o-ring system that would require significantly more belt tension to prevent slipping. Neat idea though. I'd like to see one up close before commenting too much about it.
PN makes a "reverse" pod for the NASCAR series. These might actually make a good mount option for the upcoming LM cars. There would be an issue of legality in running an advanced timed motor in a organized race setting. I guess that means that the motor manus will have get on the ball about correcting the timing issue.
Joe Chen
www.reflexracing.net
Houston, TX
Mini-Z World Champions!
Reflex Racing Blog
Reflex Racing YouTube
Old 2008.01.21, 01:30 PM   #19
Wolf
Wolf's Avatar
Too many comments to handle and I have too many new products to announce and make them ready by the end of this month. So, please excuse my short or too direct responses.
@ruf
Since cris works for you at the moment, be sure that you'll test one of these if you and cris has time for it. Meanwhile I couldn't get the point why we should need extra tension due to friction damper. And please note that this not a O-ring but its belt just like the ones in the casette players
@wcrotty
Our cars are really light in weight (150-160gr), torque of the motors are not comparable to 540 size motors. So we thought that belt would be sufficient to hold this car without any slipping. And we've seen this after the tests we had
@daveg
I don't know why others haven't done this yet but sometimes very simple ideas might be missed by many people.
About amper draw; It will not be a fair test. A motor withan advance timing will try to draw more current and will become more efficient and will produce more rpm regardless of the transmission. What observed so far more fluent car in and out of corners and your finger on the throttle is just like attached to the car. We had more rpms and more topend speed with the same ratios in the expense of a little decrease in runtime but this is negligible regarding current race times.
@programmers
Belt sits in a slot both in pinion and spur. We haven't had getting off the wheel experience despite too many accidents and crashes (some intenionally, some of them not )
@all
Yes if you overpull the motor, belt will create too much tension which might create negative issues. But with the current inertia of the car a small static tension is enough to create necessary tension on the belt.
Now my question is why nobody comments on the alternatives that we might have on gear ratios? Or how light this diff can be with lighter materials?
Sinister
Old 2008.01.21, 01:37 PM   #20
Wolf
Wolf's Avatar
@ruf
Sorry for the misunderstading. I got your point now. But my comment about o-ring versus belt stays. We've also tried this with o-ring and you are right. We would need extra tension with a rubber or silicone o-ring. Thats why we opted for drive belts instead of o-rings
Sinister
Old 2008.01.21, 04:21 PM   #21
Well, my comment about tension remains standing. A toothed belt is always run loose, this significantly reduces the amount of drag in the transmission. I'm pretty sure your customers would have more peace of mind too, knowing that the belt will not slip should some oil get into the system (as is often the case for greased ball diffs).
Regarding the weight of the diff: It looks light as is (care to put it on a gram scale for us?), but I'm pretty darn sure you can make it even lighter if you use Delrin hubs and mill some thin pressure plates.
Old 2008.01.21, 04:53 PM   #22
rharris
that Orange car is fast..
rharris's Avatar
I believe Wolf that there is no issue with the belt slipping or coming off. And I'm sure that it's not too tough to figure out if you have enough tension (or too much).
Think of how belt systems work in cars that drive water pumps, AC, power steering, etc. They are just sitting in a grooved pulley. Much greater forces are at play in a car.
When will this be ready for the rest of us?
What would the cost be?
How will you sell the pulleys? Just in sets for the motor pinion? Or different differential pulleys as well?
Very cool idea guys, I look forward to seeing one in person.
Old 2008.01.21, 11:50 PM   #23
mikez
DGAF
mikez's Avatar
Send a message via AIM to mikez
WOW, great idea! Now the awd need a kit -mike
mikez is offline   Reply With Quote
Old 2008.01.22, 12:08 AM   #24
Wolf
Wolf's Avatar
We have limited stock for this item at the moment. First batch of mass production will be ready around mid february. It will be sold as the other differentials on the market. ie some pinions will also be included in the differential set. Of course there will be replacement and optional pulley both for the diff and motor. Total differential set price will be around again regular differentials. We have some extra unit cost due to CNC machined spur and pinion but we'll try to compansate this.
As for the weight there are many more reason why it is lighter in design. For example; extra lightened spur, smaller balbearing (3x6 instead of 3x7) etc. I'll weight it whenever I have time for that.
As rharris also pointed out flat belts are capable of transferring higher loads and preffered in many industry applications. Timing belts are for the applications which needs exact timing synch for the shafts or belt size is not enough to carry required torque (like 1/10 scale cars.) Moreover timing belt was out of question in our design phase due to limited gear ratios.
Sinister
Old 2008.01.22, 02:22 AM   #25
cool idea... waiting and watching...
and wondering how much it'll cost...
would definitely like to see it installed in another motor pod/mount...
i.e. kyosho stock motor pod (hm, rm, mm); atomic; pn etc... etc...
Old 2008.01.22, 04:50 AM   #26
Programmers
iTomCash
That's fantastic then. I might have to get me one of those!
Old 2008.01.22, 07:41 AM   #27
lsarccc
Smile
Very nice! You Sir, will see the colour of my money
lsarccc is offline   Reply With Quote
Old 2008.01.22, 08:54 PM   #28
Felix2010
I am very impressed with this BDDS and I myself am hoping to be able to purchase one when they become available.
But could you please delve more deeply into the data you've uncovered regarding the motor negative-timing issue that you've come across Wolf? How is it you tell that 90% of the motors you've come across are negatively-timed for Mini-Z use (For Forward throttle-position) instead of being neutral in timing or advanced-timed for Forward throttle position? Also, what about in the case of Atomic's new Evolution Series motors the STOCK-R and the CHILI? I have heard (Not for an absolute fact) that the new Atomic M1 brush design is specifically designed for optimum (Advanced) timing for Mini-Z usage (Forward throttle). Have you tested the timing on these two motors?
Thank you for your help with this
Old 2008.01.22, 09:34 PM   #29
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
the m1 brushes have more of a wrap around the comm,changing the timing and producing more torque from the increased surface area.
the thing that bothered me with the old design is,as the brushes wear the timing changes quite a bit,especially if the endbell isnt fitted straight.
stock motors and machine wound vary + or - 5deg on average,ive seen some as much as -10deg!!
i have 2 stock r's on my to play with list.ill check the timing on them soon
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2008.02.25, 06:07 AM   #30
tudor_47
tudor_47's Avatar
mk2kompressor!
how did it go with the timing check of the stock-r??
/Johnny
Get a P28
TGR Sinister Chassis and TGR Sinister Pro Chassis Kel Parts and Hop-ups 36 2007.10.11 02:28 AM
