Go Back   Mini-ZRacer.com Forums > Manufacturers > TGR
Old 2008.02.25, 02:04 PM   #31
Ninja
Mechanic
Ninja's Avatar
I was building some motors a while back, and came up with several very fast motors. I thought I was correct, but this confirms it. I had 2 motors that stood out above the rest, far and beyond. I even had another guy building motors, trying to build a faster motor that was "stock board" safe. We are running the old 3004 boards. I used the PN ball bearing motor can. An armature out of an X-Speed motor. Magnets out of an X-Mod stage 2 motor. I accidentally put the magnets in backwards. And it didnt click untill he asked me "Why are your motor wires backwards?" Hope this helps some guys out there build some faster motors.
Real Racers Do It Sideways.
Old 2008.04.04, 12:33 AM   #32
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
we got the belt drive system for a bit of a test
so far its looking really good,ive run it in my AD mr-02 with stock r,you cant hear the car at all
it feels plenty different to a gear diff,kind of driving a turbo 1/1 car.
the actual diff action is very smooth,i havent had the chance to sand the bearing surfaces down just yet,all the adjustment is in the side nut making it ver easy to tune
more pics soon......
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2008.04.04, 01:04 AM   #33
Programmers
iTomCash
Any chance you can post a a quick video for us Matt?? I think I speak for a few of us when I say I've been looking forward to this.
Old 2008.04.04, 01:22 AM   #34
mk2kompressor
im on it
as soon as i can get up to nobby's attic with it,probably do the open car first as the sinister is having a little bit of work done
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.04.04, 02:32 AM   #35
tudor_47
tudor_47's Avatar
This is OT but
I see you are running a "normal" damper spring plate system there....
are you using all the parts post and both springs?
And have you mad ethe hole in the carbon piece from the motor pod bigger??
I also have the BDDS but it is not mounted I am waiting for replacement parts after craching my sinister in HURDA in Jonkoping last weekend...
EDIT:
you are even running the newest toplid!! Is it working can it hold the batteries in place? Even wiht a stronger motor like the chili??
and what if you run into things can it still hold the batteries in place?? And were did you get it? directly from TGR?
Thanks!
/Johnny
/Johnny
Get a P28
Old 2008.04.04, 02:42 AM   #36
mk2kompressor
yup still experimenting with an rcp setup
its got blue atm disc damper springs, .8mm side plates,.5 castor/1 camber top brace,kyosho yellow front springs/atm spring mounts and tgr wide rear/30deg atm aw fronts(im thinking slick r though)
just machining up some bigger pinions
the new top plate works,no problems so far
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.04.04, 04:05 AM   #37
tudor_47
tudor_47's Avatar
let us know how it turns out! If it turns out good maybe we all could get some pinions from you!?
Are you running without the rear springs?
For the race last weekend I had the sinister black on one side and an orange ATM spring onthe other side (to get rid of tweak)
/Johnny
Get a P28
Old 2008.04.04, 04:51 AM   #38
mk2kompressor
i have the black springs fitted for now(need to test)as the tgr damper holds it up on its own.
the pinions look good so far,i have one on my mod mr-02 right now
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.04.04, 06:14 AM   #39
Wolf
Wolf's Avatar
Matt;
I'm glad that you are up and running . You should have 3 pinions alread and you still need larger ones? Standart pinions we have are 2.3,2.6 and 3.0mm. Since the diff has 17mm diameter you should have 5.6 ratio already.
As you; said feeling of the car totally changes with BDDS. When I first drive it, it was like using brushless motor first time while racing brushed motors.
I wonder why you switched to plastic plates instead of carbon ones?
Johnny,
I hope you receive your suspension plates soon and let us know what you think about BDDS
Sinister
Old 2008.04.04, 06:22 AM   #40
mk2kompressor
wolf i need to catch you on msn
just testing things with the plastic dd plates,i need some instructions for the spinner+ too
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.04.04, 07:27 AM   #41
tudor_47
tudor_47's Avatar
mk2kompressor:
Here is a link too Spinner+ info on TGR place:
http://tgr.com.tr/index.php?option=c...d=40&Itemid=46
wolf:
I have an aditional Q? on Spinner: I have the older spinner and when I drive sinister with 9/43 gearing and the atomic chili engine the ESC start shutting down after 5 minutes...
can yuo explain this please? (9/43 is a good gearing for the engine, and the spinner is OK with the chili engine, Betteries = intellect750AAA cells)
/Johnny
Get a P28
Old 2008.04.04, 09:02 AM   #42
mk2kompressor
thanks for the link,wolf got it on there today
does your spinner get hot?
ill be testing on carpet tonight and rcp tomorrow,more pics will be in the next few hours
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.04.04, 10:19 AM   #43
mk2kompressor
just a short one for now but you get the idea,no slipping or belts flying off
ill post some pics of the steering setup in the other thread
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.04.04, 02:44 PM   #44
I wonder how the difference in on-power weight transfer (compared to a pinion/spur based diff) affects handling, MK2... have you tried this on the track yet?
Old 2008.04.04, 03:22 PM   #45
mk2kompressor
yup,ive had the bdds fitted to my ad 02 the last week or so,on rcp it actually helps me go round corners
ill get some pics and a vid of it in action on the 02 soon
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
TGR Sinister Chassis and TGR Sinister Pro Chassis Kel Parts and Hop-ups 36 2007.10.11 03:28 AM
