Old 2008.01.28, 07:39 PM   #1
rclifeform
suspension help?
Hi, I have the new friction damper and I am using the 1.0 mm suspension plates. The rear end of my car hops/stutters when going around corners. Does anyone have any tips on how to fix? Thanks
rclifeform is offline   Reply With Quote
Old 2008.01.28, 07:55 PM   #2
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
try softer damper springs and .8mm side plates
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2008.01.29, 01:44 AM   #3
Wolf
Wolf's Avatar
Matt's suggestion is valid but if you don't have softer plates I suggest you to remove rear springs totally. This will also help with your problem.
Infact, Ozgur's setup is currently just like this. 1.0mm suspension plates + friction + no rear springs + BDDS and car flys like a hovercraft on RCP
Sinister
XMod Generation 1- Rear Right Suspension Binding Flat 4 Racing Xmods 5 2007.03.07 10:44 PM
MR-01, MR-01F, MR-02mm (enzo), MR-02rm (nsx), OL, Monster, F1 TNB Autoscales, Bodies, Cars and Drivers 47 2004.08.22 05:29 PM
Sticky front suspension chelboed Mini-Z Overland MV-01 3 2003.07.15 06:32 PM
Bodies, Suspension, Tires? mlepage Parts and Hop-ups 26 2003.03.11 09:40 PM
Suspension setup tip butler Setups 9 2002.02.01 03:02 AM
