Old 2008.03.03, 03:00 AM   #1
Hunty
Hunty's Avatar
What can i use
Well when i got my mini-z i dident get nothing to gte the wheel nuts of is there aneything i can use to get them off :P
Hunty
Thnx for help if you do give me some :P
Hunty is offline   Reply With Quote
Old 2008.03.03, 06:35 AM   #2
Scrapper
Stu
Scrapper's Avatar
Send a message via MSN to Scrapper
aRE U ABSOLUTELY SURE THERE ISNT A RED TOOL
Swaggerific Boss Status
Scrapper is offline   Reply With Quote
Old 2008.03.03, 06:46 AM   #3
byebye
byebye's Avatar
The Ready to Run kit comes with a tool to remove the nuts. I suggest you purchase some alloy nuts from the shop here and at the same time buy the Atomic 3 in 1 tool. The tool has a cross tip screw driver, hex key, and wheel nut socket.
Kris
Old 2008.03.03, 07:40 AM   #4
Hunty
Hunty's Avatar
I didn't get one for sure but when i gte my next payment i will buy some
Old 2008.03.03, 11:08 AM   #5
HammerZ
Master of Thrash
HammerZ's Avatar
The stock MR01 plastic nuts are 5.5mm in size. Without the red T tool I have used my fingernails to twist them off. Then the 4.5mm locknuts to replace them with. Those MR01 nuts are known to strip out very quickly. For nutdrivers make sure you get a thin walled type. I have also used the Tamiya four way tools that come in the 1/10 kits, you can get those separately. Those are good to have on hand. Just look for a Tamiya Tool Bag.
Old 2008.03.13, 12:31 PM   #6
AlloyENZO
Just order the Atomic ones in a color of your choice along with their tool. I bought the nuts and not the tool and the cheap plastic Kyosho one has already stressed in the weak parts and basically broke.
AlloyENZO is offline   Reply With Quote
