Old 2008.03.10, 03:54 AM   #1
tudor_47
tudor_47's Avatar
Sinister driving
Hi
I have got my Sinister to drive.
I have however a few worries....
The suspension is probably binding somewhere as it tends to bounce a little in the rear when taking curves at speed. ....
setup now:
in front:
supplied springs and Kyoshos 0 degree knuckles(plastic) +3 atomic dish wheel.
a .2mm washer above spring to fill void.
in rear:
supplied springs, black
TGR friction damper with supplied spring and TGR friction grease.
.8mm suspension plates on the side. 2 nuts above the bottom plate for droop as atomicmods suggestion.
Anybody out there driving the sinister that has ideas?
thanks!
/Johnny
/Johnny
Get a P28
Old 2008.03.10, 05:05 AM   #2
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
softer springs on the disc damper and lighter oil
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2008.03.10, 07:56 AM   #3
tudor_47
tudor_47's Avatar
OK i will try that as soon as possible.
Are you running the original king-pins in front?
I think the quality and fit of them are well not the best and the knuckles can be moved side to side with them.
I guess it would be easy to modify a Atomic king-pin to fit (shopping off the e-clip part) and then the fit for the knuckles would be better.
/Johnny
/Johnny
Get a P28
Old 2008.03.10, 12:46 PM   #4
mk2kompressor
i just give the originals a polish(in a dremel or drill)the same as i do with my atomic pins,the stockers are stainless too
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
FS: TGR Sinister Chassis NIB El Tigre Mini-Z Marketplace 0 2008.08.28 11:06 PM
TGR Hurda Challenge UK Jonny Stafford Mini Z Racers England 79 2008.02.01 05:02 PM
TGR Sinister Chassis and TGR Sinister Pro Chassis Kel Parts and Hop-ups 36 2007.10.11 03:28 AM
Driving Down I-75 Draconious Miscellaneous Discussion 6 2005.01.31 12:28 AM
Favorite Driving Areas? XtremeDareDevil Mini-Z Overland MV-01 7 2003.06.04 04:13 PM
