Old 2008.03.25, 09:13 PM   #1
fpipo
HELP...Full throttle problems
I receive my new car and I setup the control With the manual but If I pull to full throttle the motor Stop.
I do not know what I need to move to correct this, any Help?.
Regards
fpipo is offline   Reply With Quote
Old 2008.03.25, 10:44 PM   #2
greetings and welcome to the forums...
try adjusting throttle trim push it up till car's wheels move forward...
here's something i posted regarding reverse, but you can use it to initially adjust / set your throttle... http://mini-zracer.com/forums/showthread.php?t=27704
1. basically raise your car off the ground (so it doesn't run off unsuspectedly) fiddle around with the throttle trim (press A/up) till the wheels start moving forward
2. then adjust throttle trim (press B/down) till the wheels stop, then press B a few more times until beeping sound from the chassis stops
3. finally press B 8 more times (might be 7,8,9 or more - i guess 8 is more or less the benchmark)
reverse should work a lot better now. almost like the am mr02 chassis...
you can use this method if your car is initially going in reverse - just press A till it goes forward. then go through the whole process again...
if it still doesn't work, try to reset the transmitter.
hope this helps...
Old 2008.03.26, 03:05 AM   #3
Rune
Mini-Z Norway
Rune's Avatar
If the motor stops when going full throttle forwards, try changing the batteries in the radio. This could help.
Old 2008.03.28, 05:09 PM   #4
Racer-HH
Racer-HH's Avatar
Try resetting the radio. This solved this problem for me.
Racer
car doesnt track straight under full throttle Action B Mini-Z AWD MA-010, MA-015 2 2008.09.28 03:38 AM
Runaway Throttle TITANIUM Parts and Hop-ups 10 2005.03.15 09:43 PM
Strange Overland problems... Like nothing I've seen before Ryan Gardner Mini-Z Overland MV-01 6 2005.01.10 10:44 PM
steering doesn't work at full throttle c0ckeyed00 Mini-Z Overland MV-01 2 2004.01.20 11:12 PM
Throttle sticks... walds11 Beginner Questions 3 2003.06.13 11:47 AM
